Nous A1Z shows wrong power
Hi all,
my smart zigbee socket Nous A1Z (connected via Zigbee2MQTT and a Conbee 2 stick) shows after a failure (fuse blown out) for my washing machine a power (sensor.wm_power) of no more than 250 watts, which is completely unrealistic and different than before (up to 2500 watts). However, the consumption (sensor.wm_energy) is apparently correctly determined and does not match the power value.
I have tried to re-pair the socket. But it doesn’t reset it that completely, because the energy consumption remains.
Has anyone experienced this problem before? And does anyone know if and how to completely reset the plug to factory settings?
Thanks in advance for any hint!
Regards
Rado
got the same or an similar problem. My Nous A1Z zigbee socket show 0,39 W in HA but something different in Zigbee2MQTT.
Did you found a solution?
Regards
Boris
I have several NOUS A1Z here, too (although integrated via ZHA, not Z2M) that work fine. However, the latest ones I added don’t show any power measurement at all (0 W, 0,0 A, 0,0 kWh) although a consumer is powered on through this plug.
Haven’t found a solution, yet. :man_shrugging:
