I have a problem with the NOUS A4Z ZigBee smart power plug. It seams that I can not control the output individually. And at the same time the power meter is showing the same power on both port even though only one port is connected. Then there seams to be a problem with the power meter values, it shows the wrong current and power.
Are there someone else that have experienced this and have a solution?
Hello Per,
Yes, I have a similar issue like you: In the beginning I wasn’t able to control the outputs individually but after a re-pairing this issue was fixed.
I’m however still experiencing exactly that same issue with the power meter as you: the same power value is reported on both ports (independent if I turn on output 1 or 2). Most anoying.
Anyone else experiencing this and have found a solution?
