I have secerts.yaml in esphome directory. I also have esp-home.test.yaml in the same directory I use to learn setting things up.
In esp-home.test.yaml I have
wifi:
ssid: !secret wifi_ssid
It loads fine.
I want to move WiFi configuration into package. I created directory esphome/packages and created file wifi.yaml containing this code:
wifi:
Editor shows error: Could not open ‘/config/esphome/packages/secrets.yaml’
I want it to use /config/esphome/secrets.yaml but do not know how to set that up.
If I copy secrets.yaml into packages directory then it seems toload it but now i have two secreats files, which I do not want to.
And now I get new error: ‘esphome’ section missing from configuration. i cannot find anything related to this error.
What I am doing wrong?
