Novy remote control in HA using RFXTRX?
Hi guys, new on the block in HA. Currently using HA on a Pi (3b) with an RFXTRX433e connected to it.
Now I’ve got a Novy hood in my kitchen which should use the 433.92 mhz freq. But so far I am unable to read/find the signal.
Does anyone have an idea?
Best is to contact RFXCOM because Novy is not (yet) supported by the RFXtrx.
Just got a Novy hood too.
If I understand correctly it seems it has been integrated last month
FW release 433_1040 12-08-2019
  • Novy extractor hood added
I’ve never played with RFXCOM.
Which transceiver should I buy if it’s compatible ?
Thx
Yann
The RFXtrx433E with Pro2 firmware and the RFXtrx433XL are able to control Novy.
Note that the RFXtrx433E is EOL and is replaced by the RFXtrx433XL.
Thx for the info.
I just bought it.
So, I received the RFXtrx433XL.
I launched the RFxmngr, enabled undec on & Byron SX/BY, SelectPlus.
Then, when I click on the remote, I can see data in RFXmngr.
When I go into Fan tab, select Novy, I can interact with the hood.
But when I reconnect the RFXtrx433XL into HA, and click on the remote, I get nothing in the log.
The switch doesn’t appear into the ui.
I can’t find what I’m missing.
First time with 433…Mhz
Thx
Did you enable the HomeConfort, Fan protocol for receive?
Nope
Not this one. I’ll try.
Do I only need this one ?
Thx
New try with :
10/2/2019 04:51:23:641= Get Status: 0D 00 00 04 02 00 1C 00 00 00 00 00 00 00
10/2/2019 04:51:23:762= 14010004025329A000000203001C107C4658434F4D
Packettype        = Interface Message
subtype           = Interface Response
Sequence nbr      = 4
response on cmnd  = Get Status
Transceiver type  = 433.92MHz
Firmware version  = 1041
Firmware Type     = ProXL1
Noise level       = 124
Transmit power    = 10dBm
Hardware version  = 3.0  RFXtrx433XL
Undec             on
Imagintronix      disabled
Byron SX          enabled
RSL               disabled
Lighting4         disabled
FineOffset        disabled
Rubicson          disabled
AE Blyss          disabled
BlindsTx          disabled
BlindsT0          disabled
Legrand           disabled
La Crosse         disabled
Hideki            disabled
AD LightwaveRF    disabled
Mertik            disabled
Visonic           disabled
ATI,Cartelectroni disabled
Oregon Scientific disabled
Meiantech         disabled
HomeEasy EU       disabled
AC                disabled
ARC               disabled
X10               disabled
HomeConfort,Fan   enabled
KeeLoq            disabled
I clicked on the light button of the remote to test and I got :
10/2/2019 04:53:25:278= 547F0000011D3A17E8013A01D3028B033D012301D60286033D012501D3028C033B012501D2028C033C012201D4028C033C0123033B0123033B012501D5028B033C012401D4028B01D4028C01D50287033D01250000
Packettype    = RAW Packet
Packet Length = 84
subtype       = RAW packet
Sequence nbr  = 0
Repeat        = 1
Nbr of pulses = 20
7482  6120  314  467  651  829  291  470  646  829  293  467  652  827  293  466  652  828  290  468  652  828  291  827  291  827  293  469  651  828  292  468  651  468  652  469  647  829  293  0
10/2/2019 04:53:25:401= 507F000101011601D2028B033D012501D3028B033A012501D60289033D012301D4028B033C012601D4028A033D0124033B0122033A012701D3028C0339012601D6028701D9028801D5028A033E01210000
Packet Length = 80
Sequence nbr  = 1
Repeat        = 1
Nbr of pulses = 19
278  466  651  829  293  467  651  826  293  470  649  829  291  468  651  828  294  468  650  829  292  827  290  826  295  467  652  825  294  470  647  473  648  469  650  830  289  0
10/2/2019 04:53:25:600= 507F000201011F01D6028A033B012401D4028C033B012501D70288033A012701D3028C033C012301D4028C033B0125033A0123033B012701D2028C033C012401D3028E01D2028C01D4028C033A01270000
Packet Length = 80
Sequence nbr  = 2
Repeat        = 1
Nbr of pulses = 19
287  470  650  827  292  468  652  827  293  471  648  826  295  467  652  828  291  468  652  827  293  826  291  827  295  466  652  828  292  467  654  466  652  468  652  826  295  0
10/2/2019 04:53:25:862= 507F000301012201D2028C033B012501D60289033C012501D70286033E012301D50289033D012401D6028A0339012803390124033B012601D60289033C012401D5028901D9028801D60289033B01260000
Packet Length = 80
Sequence nbr  = 3
Repeat        = 1
Nbr of pulses = 19
290  466  652  827  293  470  649  828  293  471  646  830  291  469  649  829  292  470  650  825  296  825  292  827  294  470  649  828  292  469  649  473  648  470  649  827  294  0
I disconnect from RFXmangr, plugged the RFXtrx433XL back into HA, restarted HA with the config below :
root@oahu:~# dmesg | tail -1
[169869.671875] usb 1-4: FTDI USB Serial Device converter now attached to ttyUSB1
root@oahu:~#
logger:
  default: error
  logs:
    rfxtrx: debug
    homeassistant.components.rfxtrx: debug
rfxtrx:
  device: /dev/ttyUSB1
  debug: true
switch:
  platform: rfxtrx
  automatic_add: true
I then click on the same button on the remote, nothing in the log, no switch added automatically into HA.
Thx for your help
Without “debug on” you should normally receive a Novy packet.
I suppose the pulse timing is out of the ranges set in the firmware and needs some tuning by RFXCOM.
Check with RFXmngr if you can control your Novy hood using ID = 1
Yes I can control everything in the Fan tab, selecting Novy with ID 1
I didn’t try without the debug,
I will tomorrow to test.
Still nothing after removing debug
How can it works with RFXmng and not in HA ?
You will need an updated firmware to receive your Novy remote.
Please contact support rfxcom.com
@amans I am having similar problems, can send from RFXmanager but received packets are not decoded (I am in contact with rfxcom about this).
But did you ever get this to work, and if so, could you share the ID’s of the buttons in HA? That way I can add them manually.
Thomas
@thomas-be I didn’t had the time to contact rfxcom as suggested by @b_weijenberg.
In one of my previous posta above I wrote everything I’ve done.
I did retry today but still nothing in the logs.
No switch added.
You can’t see the same type of logs than me in rfxmngr when you click a button of the remote ?
I’ve to tick the “undec on” to see the packets.
@amans AFAIK choosing undec_on will not help, you need the decoded messages which only the RFXtrx device can do, not Home Assistant. The Novy remote does not work, probably there is some difference between the timings of different remotes. The developer said he would look into is as soon as he has the time (which I really appreciate). A firmware upgrade will probably be needed.
Thomas
I have a Novy hood. It works through the RFXcom. When I send a signal through the RFXcom-manager, the hood comes on.
The question is now. Can I integrate the Novy cooker hood into Home Assistant? Perhaps this is a question for the designers of Home Assistant. In Domoticz they say that despite the fact that the Novy works via RFXcom, it cannot work in Domoticz because of the very different coding of the signal. Does this also apply to Hassio?
If not, how do I integrate the Novy?
I just contacted rfxcom.
And Bert Weijenberg
@b_weijenberg I suppose it’s you :slight_smile:
I don’t understand.
On this forum, you’re telling me to contact rfxcom, but when I contact them you’re answering to check the forum ? :rofl: :joy:
What should I do to make it work ?
Perhaps only something I’m not doing correctly ?
Thx
As I told you just by email, this is only the case when Novy could not be controlled using RFXmngr.
As I said in my first post :slight_smile:
So… now ?
What am I doing wrong ?
