NR 12.0.2 Stopped again
Shortly after upgrading to 12.0.2, the add-on just stopped. It happened to someone else then (NodeRED self stop since update to version 12.0.2), and like @ piriya2544, I restarted the add-on from the add-on manager and everything worked again.
It happened again tonight. The Node Red add-on spontaneously stopped.
Is this happening to anyone else?
it seem to be better now for version 12.0.2
where’s the log?
I didn’t see any errors, but the next time it happens I will save the log file ASAP.
(You do mean the Node-Red logs?)
Yes but it doesn’t hurt to also check the HA logs as well.
