NSPanel: impossibile set temperature into thermostat page
I have an nspanel with tasmota.
I can’t set manually termperature into thermostat page of nspanel or set manual mode (it is always set on auto mode).
I tried by tasmota console to run follow commad, but not works…
NSPSend {"ATCEnable":0,"ATCMode":0,"ATCExpect0":27}
NSPSend {"ATCEnable":1,"ATCMode":0,"ATCExpect0":27}
Ideas???
Hello :slight_smile:
If you want set temperature via hassio or in tasmota use command cmnd/nspanel/nspsend {"ATCMode":0,"ATCExpect0": value for temperature} if you want use manual or automatic thermostat change ATCMode 0 is manual 1 is automatic. If you want turn off thermostat add command in line "ATCEnable":1 0 is off 1 is on
in nspanel.be you have to change:
class NSPanel : Driver
  # set thermostat options
  static atc = {
    "id":     "thermostat",
    "outlet": "0",  # outlet to use for trigger
    "etype":  "hot", # hot or cold
    "mirror":  false, # if true Tasmota will resend triggers as commands to keep the state on screen
to:
  static atc = {
    "id":     "thermostat",
    "mirror":  true, # if true Tasmota will resend triggers as commands to keep the state on screen
“mirror”: true,
then in configuration.yaml add:
under switch:
  - platform: mqtt
    name: "NSPanel relay 1"
    state_topic: "stat/NSPanel/POWER1"
    command_topic: "cmnd/NSPanel/POWER1"
    availability_topic: "tele/NSPanel/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    retain: false
and under sensor:
  - platform: mqtt
    state_topic: "tele/NSPanel/SENSOR"
    unit_of_measurement: "°C"
    value_template: "{{ value_json['ANALOG'].Temperature1 }}"
then to have the thermostat running in HA (but not on the panel):
climate:
  - platform: generic_thermostat
    heater: switch.nspanel_relay
    target_sensor: sensor.nspanel_temp
    min_temp: 10
    max_temp: 30
    ac_mode: false
    cold_tolerance: 0.3
    hot_tolerance: 0.3
    min_cycle_duration:
      seconds: 5
    keep_alive:
      minutes: 1
    initial_hvac_mode: "heat"
    away_temp: 16
    precision: 0.5
to make it work from panel (to set the temp) maybe rules will help?!?!?!?
Did you got to implement the thermostat with the nspanel and tasmota?
Red the nspanel protocol page but not sure about the following;
how to display the temperature (at the nspanel) of the built-in sensor with one decimal.
Searched in various articles but unable to find it.
could anyone give me a hint please ?
thanks
H
