NSPanel: no weather on screensaver
Hi Folks,
I have now loaded my NSPanel with Lovelace, it works satisfactorily so far.
Only I have on the Screensave exclusively the date and time, no weather data.
MQTT broker is running and connected - otherwise the panel would not show anything.
Does anyone have an idea?
My app.yaml:
nspanel-1:
module: nspanel-lovelace-ui
class: NsPanelLovelaceUIManager
config:
panelRecvTopic: “tele/nspan1/RESULT”
panelSendTopic: “cmnd/nspan1/CustomSend”
sleepTimeout: 20
sleepBrightness:
- time: “7:00:00”
value: 10
- time: “23:00:00”
value: 0
locale: “de_DE”
I found the error!
In the apps.yaml the entity entry with the weather entity was missing.
screensaver:
entity: weather.home_station
I have everything set up in the right way, but I do not have any detail under the time and date. can you show me with a screen your app.yaml?
Frederico, I had the same problem but it work for me:
Goto home assistant menu developer tools, tab states.
in entity type weather and will show your entity in my case weather.casa
use it at:
screensaver:
  entity: weather.casa
Hi folks!
I had the weather shown on my NSPanel, but since quite a while it’s gone. What did I miss to get it running? I think there was a change in Home Assistant Core?
