NSPanel Pro now natively support Home Assistant
I can’t find any information about the release note on the web for now, but my Nspanel pro received firmware 3.7 yesterday, and great news, it natively discovers Home Assistant on the network.
You will get a full screen access to HA on a dedicated screen, just perfect. Working good for now. Much better than the web page shortcut I used previously.
And don’t forget that it can be turned into a Zigbee Router, which is great too to extend your Zigbee network range.
A christmas miracle!
The native web app support for Home Assistant is a nice addition - that firmware seemed to hit mine about a day after receiving the unit. Before doing all the Android customization I think I’m going to wait it out on this firmware and see how things go. So far it’s a been a bit flaky - at times it seems to “lose” the web app after reboot and I have to re-add it, but it has my login cached so it’s a pretty quick thing to do. Most of the time my panel is running 24/7 anyway - most of my reboots have just been me playing with the device so far. It would also be nice if we could boot straight into a web app, but at least having a shortcut on the desktop isn’t too bad.
Pretty much the same feeling than you. Not really different that the we view shortcut I used previously, just a bit simpler.
I have ordered a NS Panel Pro 120 that will be much better to display HA screen.
I am thinking of getting those NsPanel Pro 120s. Is it better to have on the wall vertically or horizontially for custom Home Assistant dashboards?
Personally I use it vertically, u have the same feeling than with a smartphone
How are you finding it?
Good. The only issue is that the firmware is not very stable, the device does reboot by itself from time to time.
Hey @mcc37 ! I asked on the forum about this but I got no reply. I wonder if you know this.
The NS panels are advertised to replacel light switches but I wonder if I can wire it with the wires of a power socket.
I have a spare power socket at chest level in the kitchen and it would work perfectly for the Ns panel.
I am European for reference.
Thanks in advance!
of course, that’s why they sell a stand, so you can just wire it and plug it in a power socket!
Yep, it’s the easiest way :grinning:
there has been a few updates from when the original post was posted.
how is it now?
I just got one today on the amazon spring sale. I have it powered up and working. I was able to display a HA dashboard using the including browser. Next is seeing how I can use it to control some RBG lights as that is my main use case. If you have something you want me to try let me know and I see what I can do.
I’m wondering how much access this version allows for its microphone and camera.
Could you please try using it with SIP HASS card?
Only thing that I like better about the esp versions of the NSPANEL is that it functions as a device in HA so much better. you have access to the device things like relays and playing tts and such. so far I haven’t found a way to do that with the pros. I got a 120 pro yesterday and just starting to play around with it.
Digging this one up
How do you trigger this discovery?
I’ve just moved everything over from Sonoff to HA Zigbee and paired the NSP running in router mode with the ZB service and all is good
I didn’t factory reset or start again and would like it to see HA
Hi, I’m looking for a wall pannel, especially to control led light color and intensity which soemtimes is really anoying to control with a zigbee button, however I seen this , which could be a game changer ( a bit more expensive of some tya and meroos device I was looking). question is this now the standard and best choice to go with? and where to find it a best price on UK ? aliexpress?
thanks
S.
Hello, Im thinking of buying the panel. Has it worked well?
Yet, it works well despite a bit slow.
Do you mean one needs a plug and some 3 core flex and one just wires that into the back of the panel?
