NSPanel(US) Blueprint version mismatch!
I keep getting “Blueprint version mismatch!”
I am on version 4.24 for ESPhome, TFT and Blueprint.
What can I do to fix this error?
[18:39:30][I][script.watchdog:3115]: Wi-Fi:         Excellent (-47 dBm)
[18:39:30][I][script.watchdog:3135]: API:           Connected
[18:39:30][W][script.watchdog:3155]: Blueprint:     Pending
[18:39:30][I][script.watchdog:3156]: Requesting blueprint settings
[18:39:30][I][script.watchdog:3166]: ESPHome:
[18:39:30][I][script.watchdog:3167]:   Version:     4.2.4
[18:39:30][I][script.watchdog:3172]:   Framework:   esp-idf
[18:39:30][I][script.watchdog:3176]: UART:
[18:39:30][I][script.watchdog:3177]:   Baud rate:   115200 bps
[18:39:30][I][script.watchdog:3178]:   Queue size:  0
[18:39:30][I][script.watchdog:3182]: Nextion:
[18:39:30][I][script.watchdog:3183]:   Queue size:  0
[18:39:30][I][script.watchdog:3185]:   Is setup:    True
[18:39:30][I][script.watchdog:3192]:   Init:        True
[18:39:30][I][script.watchdog:3200]:   TFT:         4.2.4
[18:39:46][D][script.check_versions:1744]: ESPHome version: 4.2.4
[18:39:46][D][script.check_versions:1745]: TFT version: 4.2.4
[18:39:46][D][script.check_versions:1747]: Blueprint version:
[18:39:46][E][script.check_versions:1748]: Blueprint version mismatch!
[18:39:46][D][script.check_versions:1756]: Framework: esp-idf
[18:39:46][D][script.check_versions:1757]: Baud rate: 115200
[18:40:22][D][sensor:094]: 'kitchenpanel RSSI': Sending state -48.00000 dBm with 0 decimals of accuracy
[18:40:24][D][sensor:094]: 'ntc_source': Sending state 1.54200 V with 2 decimals of accuracy
[18:40:24][D][resistance:039]: 'resistance_sensor' - Resistance 9823.9O
[18:40:24][D][sensor:094]: 'resistance_sensor': Sending state 9823.89160 O with 1 decimals of accuracy
[18:40:24][D][ntc:026]: 'kitchenpanel Temperature' - Temperature: 25.4°C
[18:40:24][D][sensor:094]: 'kitchenpanel Temperature': Sending state 25.90039 °C with 1 decimals of accuracy
[18:40:30][I][script.watchdog:3115]: Wi-Fi:         Excellent (-48 dBm)
[18:40:30][I][script.watchdog:3135]: API:           Connected
[18:40:30][W][script.watchdog:3155]: Blueprint:     Pending
[18:40:30][I][script.watchdog:3156]: Requesting blueprint settings
[18:40:30][I][script.watchdog:3166]: ESPHome:
[18:40:30][I][script.watchdog:3167]:   Version:     4.2.4
[18:40:30][I][script.watchdog:3172]:   Framework:   esp-idf
[18:40:30][I][script.watchdog:3176]: UART:
[18:40:30][I][script.watchdog:3177]:   Baud rate:   115200 bps
[18:40:30][I][script.watchdog:3178]:   Queue size:  0
[18:40:30][I][script.watchdog:3182]: Nextion:
[18:40:30][I][script.watchdog:3183]:   Queue size:  0
[18:40:30][I][script.watchdog:3185]:   Is setup:    True
[18:40:30][I][script.watchdog:3192]:   Init:        True
[18:40:30][I][script.watchdog:3200]:   TFT:         4.2.4
