Hello
I’m starting to have problems with my RPI 4 that I run HassOS on which I do not know what it is due to. Would appreciate input incredibly much.
It started a few months ago, when I received the following error message:
AN SSL error has occurred and a secure connection to the server cannot be made. NSURLErrorDomain - 1200
The only way to get it going again was to turn on the power. Then I had to try several times before I started to unplug the power.
I have had it upstairs where it has now become quite hot (25 degrees).
This started to come more often, so I tried to remove the shell on it, then felt that the wifi part was very hot. It got better without the shell, it did not hang as often.
I decided to move it down and connect it to TP cable (ran wifi earlier on it).
BUT last night I got the same error again.
Today I have no cooling on it, but just removed the shell, have ordered a fan to be mounted on it. I have also noticed that when it loses the connection and I pull the power, it is much faster in HA when it started up.
So my theory is that it:
1, Gets too hot and hence begins to hassle.
2, Been injured by overheating several times
BUT why do I usually get the error at night?
Am I on the right track? Anyone experienced the same problem?
