Hi everyone,
I have ntc thermistor connected to esphome. if I connect +ve to 3.3 directly, no issue with the measurment. everything is working as intended.
I followed the advised as detaile in section Self-heating https://esphome.io/components/sensor/ntc.html what i do not understand is that I started seeing rogue measurement after defined internal. The sensor values are correct. After the switch is turned off, I see rogue measurement in the log. I added delay and capacitor with no improvement.
snip of esphome codes are as follows,
# Sensors with general information.
- platform: ntc
sensor: GPIO33resistance_sensor
calibration:
b_constant: 3950
reference_temperature: 25°C
reference_resistance: 10kOhm
name: GPIO33 Temperature
- platform: resistance
sensor: GPIO33source_sensor
configuration: DOWNSTREAM
resistor: 10kOhm
- platform: adc
attenuation: auto
#filters:
# - multiply: 3.3
pin: GPIO33
#update_interval: 20s
switch:
- platform: restart
- platform: gpio
pin: GPIO5
interval:
- interval: 60s
then:
- switch.turn_on: ntc_vcc
- delay: 10s
- component.update: GPIO33source_sensor
- switch.turn_off: ntc_vcc
any help greatly appreciated with thanks.
