I currently run the latest versions on Intel NUC:
Home Assistant OS 7.2
Supervisor 2022.01.0
Core 2021.12.01
My setup is pretty light:
CC2531
Zigbee2mqtt
about 10 Xiaomi temp/humidity zigbee sensors
3 Xiaomi Zigbee sockets
one Arduino Nano with Standard Firmata
One or two updates ago (one of the January releases, before my current versions) seems to have caused the NUC cooling fan to spin continuously. And 90% of the time pretty noisy, so high spinning speed, sometimes it drops the speed, but never stops spinning.
I haven’t changed my hardware or software setup, so I assume there’s some HA process consuming CPU and requiring more CPU cooling.
With the Linux top
command I can see this process constantly consuming 101 - 109% out of four core:
python3 -m homeassistant —config /config
But it’s the first time I’m looking at top
, so not sure if this normal. Sure doesn’t seem to be normal.
Memory usage is low: 6.2GB free of 7.7GB.
No other issues, other than noisy fan. HA runs for days with no crash, unlike this reported issue (which may be related, though): 2021.12.3 causes high CPU and Memory Load · Issue #62309 · home-assistant/core · GitHub
Rebooting several times did not change the behavior.
Before one of the recent updates, I never heard the fan, was probably spun just on boot.
Anyone experiencing this?
