Ferraz
July 12, 2023, 1:26pm
143
Hi guys, can anyone help me to adjust this card? I can not put the cpu temperature sensor, UPTIME and HA Version.
When I delete the variables the card works, when I put the variables the card does not work.
type: custom:config-template-card
variables: null
entities:
- sensor.disk_use_percent
- sensor.homeassistant_version
- sensor.disk_total
- sensor.disk_use
- sensor.memory_use_percent
- sensor.processor_use
- sensor.processor_temperature
card:
type: entities
show_header_toggle: 'off'
style: |
.card-header {
padding: 0px 0px 0px 0px !important;
entities:
- type: section
label: ${ 'Debian 11 --- HA Version ' + vars[1] }
- type: custom:hui-element
card_type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: picture
style: |
ha-card {
--paper-card-background-color: 'rgba(0, 0, 0, 0.0)';
--ha-card-background: "rgba(0, 0, 0, 0.0)";
--ha-card-box-shadow: 'none';
image: /local/images/intel-nuc.png
- type: custom:button-card
layout: icon_name_state2nd
show_icon: true
show_state: true
styles:
grid:
- grid-template-columns: 50px auto
icon:
- padding: 0px 0px
- height: 30px
- width: 30px
card:
- '--ha-card-background': rgba(0, 0, 0, 0.0)
- '--ha-card-box-shadow': none
state:
- padding: 0px 10px
- justify-self: start
- font-family: Roboto, sans-serif
- font-size: 15px
name:
- padding: 0px 10px
- color: var(--secondary-text-color)
entity: sensor.homeassistant_uptime
icon: mdi:clock-outline
- type: custom:bar-card
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
unit_of_measurement: '%'
severity:
to: 50
color: '#018304'
to: 75
color: '#f39c12'
to: 100
color: '#e45e65'
style: |
ha-card {
--paper-item-icon-color: 'var(--text-primary-color';
entities:
- entity: sensor.disk_use_percent
name: ${ 'Disk (' + vars[3] + 'Gb/' + vars[2] + 'Gb)' }
entity_row: true
cards:
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
to: 50
color: '#018304'
to: 75
color: '#f39c12'
to: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.memory_use_percent
entity_row: true
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
to: 50
color: '#018304'
to: 75
color: '#f39c12'
to: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.processor_use
entity_row: true
- type: custom:mini-graph-card
height: 30
line_width: 2
font_size: 70
hours_to_show: 168
points_per_hour: 1
show:
extrema: true
fill: true
style: |
ha-card {
border-radius: 5px;
.info.flex {
font-size: 12px !important;
entities:
color_thresholds:
- value: 30
color: '#3498db'
- value: 50
color: '#f39c12'
- value: 80
color: '#ff0000'
Ferraz
July 14, 2023, 11:56am
144
Hi guys,
Is it no longer possible to have uptime information in HA?? Are these the only resources available right now?
https://www.home-assistant.io/integrations/systemmonitor
# Example configuration.yaml entry with all entry types (delete/comment out as necessary)
- platform: systemmonitor
resources:
- type: disk_use_percent
arg: /config
- type: disk_use
- type: disk_free
- type: memory_use_percent
- type: memory_use
- type: memory_free
- type: swap_use_percent
- type: swap_use
- type: swap_free
- type: load_1m
- type: load_5m
- type: load_15m
- type: network_in
arg: eth0
- type: network_out
arg: eth0
- type: throughput_network_in
arg: eth0
- type: throughput_network_out
arg: eth0
- type: packets_in
arg: eth0
- type: packets_out
arg: eth0
- type: ipv4_address
arg: eth0
- type: ipv6_address
arg: eth0
- type: processor_use
- type: processor_temperature
- type: last_boot
petro
(Petro)
July 17, 2023, 11:06am
145
last_boot will give you the uptime of your system. The uptimes in this guide were manually created by me for the most part. They have since been made obsolete with the new timestamp device class as well as duration sensors.
Ferraz
July 17, 2023, 5:28pm
146
would you help me to get the information “Last Boot” and “HA Version undefined” right. Last boot information is coming out of the template.
DrewXT
(Andrew)
July 17, 2023, 11:45pm
147
is it possible to do decimal point rounding within the card?
The Synology integration now reports disk usage to 12 decimal points, wondering if I can round it down to 2 decimal points without creating another entity using a sensor or not
JulianDH
(Julian Hall)
July 18, 2023, 7:12pm
148
IF you are using the Synology integration go to:
Settings → integration-> Synology → Volume 1
Choose the entity you want to amend and go into the “cog” …it will allow you to amend the “Display precision” of the entity.
DrewXT
(Andrew)
July 18, 2023, 11:32pm
149
I’ve done that already, but it still shows 12 decimal points - I think the card is showing the sensor value rather than honouring the display precision
vs
not sure if it’s an undocumented feature in the integration or not…
JulianDH
(Julian Hall)
July 19, 2023, 8:55am
150
I have same sensor and can confirm that through normal entity card it follows the Display Precision that you set.
I am about to set up a NUC and need an updated system monitor card. I am not sure I will use this one as it appears to be quite old. But I will take a look. Perhaps somebody else might comment.
Edit: I would read the very first post statement
DrewXT
(Andrew)
July 20, 2023, 3:13am
151
Agree that it works with a regular HomeAssistant built-in card.
Not sure about your reference to first post statement
Goofi
(Goofus27)
November 18, 2023, 9:02pm
152
Hello there
can you please share your code i have the Intel NUC 13 Pro Kit RNUC13ANHI50002 Arena Canyon.
and use latest home assistant.
can you please tell me how you did it with that picture. i am kinda new to al this i tried changing a lot yaml and so on but could not figure it out.
I’m trying to get a reading of my CPU temperature from NUC10 running proxmox and HA OS.
This code is not returning anything:
- platform: command_line
name: CPU Temperature
command: "cat /sys/class/thermal/cooling_device0/processor"
scan_interval: 15
unit_of_measurement: "°C"
#unit_of_measurement: "°F"
value_template: '{{ value | multiply(0.001) | round(1) }}'
#value_template: " {{ (( value | multiply(0.0018)) + 32 ) | round (1) }}"
Anyone has a clue?
dproffer
(David Proffer)
December 17, 2023, 10:14pm
154
What does
return from the root using of your proxmox server and if you are able to do it from within your Home Assistant VM?
I made a typo somewhere
cat /sys/class/thermal/cooling_device0/type
returns processor
dproffer
(David Proffer)
December 18, 2023, 12:38am
156
Different motherboards and manufactures have different directory structures for there hardware information access. For example for some Intel motherboards I use the following structures shown in code below. Good hunting!
# get cpu temperature
try :
with open('/sys/class/hwmon/hwmon1/temp1_input', 'r') as f:
cpu_temperature = str(int(f.read().strip()) / 1000)
except :
cpu_temperature = "-1.0"
# get cpu critical temperature
try :
with open('/sys/class/hwmon/hwmon1/temp1_crit', 'r') as f:
cpu_temperature_critical = str(int(f.read().strip()) / 1000)
except :
cpu_temperature_critical = "-1.0"
# get cpu operating frequency info
core_frequency = []
try :
with open('/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq', 'r') as f:
core_frequency.append(str(f.read()).strip())
except :
core_frequency = ["-1"]
# get memory info
try :
with open('/proc/meminfo', 'r') as f:
mem_info = f.read().splitlines()
total_memory = re.search(r'MemTotal:(.*?)kB', mem_info[0]).group(1).replace(' ', '')
available_memory = re.search(r'MemFree:(.*?)kB', mem_info[1]).group(1).replace(' ', '')
except :
total_memory = "-1"
available_memory = "-1"
cnecrea
(cnecrea)
January 30, 2024, 2:19am
157
Hi there,
I would like to share with you my card. It’s a simple one. Feel free to modify it.
card:
cards:
- type: custom:bubble-card
card_type: separator
icon: mdi:home-assistant
- type: custom:vertical-stack-in-card
cards:
- type: picture
card_mod:
style: |-
ha-card img {
display: block !important;
width: 50% !important;
margin: auto !important;
margin-top: -60px !important;
margin-bottom: -70px !important;
image: /local/lenovo.svg
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
template:
- lenovo
custom_fields:
uptime: |
return `Ultima pornire, ${states['sensor.last_boot'].state}`;
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
to: 50
color: '#000'
to: 75
color: '#000'
to: 100
color: '#000'
style: ''
card_mod:
style: |-
ha-card {
border-radius: 0px !important;
border: 0px !important;
pointer-events: none;
entities:
- entity: sensor.system_monitor_disk_use_percent
entity_row: true
cards:
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
to: 50
color: '#018304'
to: 75
color: '#f39c12'
to: 100
color: '#e45e65'
style: ''
card_mod:
style: |-
ha-card {
entity_row: true
entities:
- entity: sensor.system_monitor_memory_use
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
to: 50
color: '#018304'
to: 75
color: '#f39c12'
to: 100
color: '#e45e65'
style: ''
card_mod:
style: |-
ha-card {
entity: sensor.system_monitor_processor_use
entity_row: true
font_size: 75
font_size_header: 12
card_mod:
style: |
ha-card .graph__legend__item {
margin-top: 10px
show:
points: false
extrema: true
icon: false
tap_action:
action: none
align_icon: left
align_header: left
animate: true
entities:
- entity: sensor.system_monitor_processor_temperature
name: Temperatura procesorului
- color: gray
entity: sensor.nightstate
show_legend: false
show_line: false
show_points: false
y_axis: secondary
and the template:
lenovo:
show_state: false
show_icon: false
show_name: false
tap_action:
action: none
hold_action:
action: none
styles:
card:
- padding: 5%
- color: gray
- font-size: 10px
- text-shadow: 0px 0px 0px black
- justify-self: end
- align-self: middle
grid:
- grid-template-areas: |
"uptime uptime"
- grid-template-rows: 1fr min-content min-content min-content min-content
- align-items: start
custom_fields:
uptime:
- justify-self: center
- color: gray
- font-size: 14px
- font-family: CairoPlay
- margin: '-6% 0 0 0'
Using:
lampshade29
(Lampshade29)
February 28, 2025, 6:36pm
158
Can you post your yaml for this, I would like to do this for a Synology 918+
I would but that card is now very very old and I use this layout now
gtracy
(Glenn Tracy)
July 1, 2025, 5:05pm
160
I know this is an old post but I was wondering if you got any further with this?
