Nuc System Monitoring Card
The numbered zones can differ per system as there are several thermal sensors, so you need to find out what your zones are numbered. Run both to check out:
ls -l  /sys/class/thermal/thermal_zone*
cat /sys/class/thermal/thermal_zone*/type
Here is the result
root@pve:~# ls -l  /sys/class/thermal/thermal_zone*
lrwxrwxrwx 1 root root 0 Oct 28 17:12 /sys/class/thermal/thermal_zone0 -> ../../devices/virtual/thermal/thermal_zone0
lrwxrwxrwx 1 root root 0 Oct 28 17:12 /sys/class/thermal/thermal_zone1 -> ../../devices/virtual/thermal/thermal_zone1
lrwxrwxrwx 1 root root 0 Oct 28 17:12 /sys/class/thermal/thermal_zone2 -> ../../devices/virtual/thermal/thermal_zone2
lrwxrwxrwx 1 root root 0 Dec  7 14:49 /sys/class/thermal/thermal_zone3 -> ../../devices/virtual/thermal/thermal_zone3
root@pve:~# cat /sys/class/thermal/thermal_zone*/type
acpitz
acpitz
iwlwifi_1
x86_pkg_temp
I have changed mine from 5 to 3 now the error is gone. But I got new one… :sweat_smile:
  File "/root/rpi-mqtt-monitor/src/rpi-cpu2mqtt.py", line 158, in <module>
    publish_to_mqtt(cpu_load, cpu_temp, used_space, free_space, uptime, total_space, memory)
  File "/root/rpi-mqtt-monitor/src/rpi-cpu2mqtt.py", line 85, in publish_to_mqtt
    client.connect(config.mqtt_host, config.mqtt_port)
  File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 912, in connect
    self.connect_async(host, port, keepalive,
  File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 979, in connect_async
    if port <= 0:
TypeError: '<=' not supported between instances of 'str' and 'int'
It looks like the mqtt package is not getting the right config from your script. Can you show the contents of it?
I assume the following command, be sure to check yourself
cat /root/rpi-mqtt-monitor/src/config.py
Here it is
root@pve:~# cat /root/rpi-mqtt-monitor/src/config.py
from random import randrange
# MQTT server configuration
mqtt_host = "192.168.178.34"
mqtt_user = "mqtt"
mqtt_password = ""
mqtt_port = "1883"
mqtt_topic_prefix = "rpi-MQTT-monitor"
# Messages configuration
# If this is set to True the script will send just one message containing all values
group_messages = False
# If this is set, then the script will send MQTT discovery messages meaning a config less setup in HA.  Only works
# when group_messages is set to False
discovery_messages = True
# Random delay in seconds before measuring the values
# - this is used for de-synchronizing message if you run this script on many hosts.
# - if you want a fix delay or 0 you can remove the randrange function and just set the needed value.
random_delay = randrange(1)
# This is the time  between sending the individual messages
sleep_time = 0.5
cpu_load = True
cpu_temp = True
free_space = True
used_space = True
total_space = True
voltage = True
sys_clock_speed = True
swap = True
memory = True
uptime = True
# Enable wifi_signal for unit of measuring % or wifi_signal_dbm for unit of meaning dBm
wifi_signal = False
wifi_signal_dbm = False
It looks like the package is expecting an integer, so try to remove the double quotes " around the 1883 port number in your config.
Thank you that worked! I really appreciate your help!
One more question. Even I have enabled via discovery_messages = True MQTT integration in HA don’t see sensors. But I can see them via MQTT Explorer
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
        primary: 'NUC : Versione Hassio {{states(''sensor.hass_version'')}}'
        secondary: '- {{states(''sensor.ha_start'')}}'
        icon: mdi:cpu-64-bit
        fill_container: true
        entity: sensor.processor_use
        layout: vertical
        style: |
          ha-card {
            background: transparent !important;
            overflow: hidden !important;
            box-shadow: none !important;
        card_mod:
          style: |
            ha-card {
              height: 102px;
              background: url('/local/images/nuc10-hero.jpg') center;
              background-size: cover;
              background-blend-mode: overlay;
              background-color: rgba(var(--rgb-card-background-color), 0.8);
              {% if is_state('light.geekroom', 'on') %}
                  box-shadow: 0 0 20px rgba(0, 150, 136, 0.6);
              {% endif %}
        tap_action:
          action: more-info
  - type: custom:stack-in-card
    mode: vertical
    cards:
      - type: custom:apexcharts-card
        chart_type: radialBar
        series:
          - entity: sensor.disk_use_percent
            color: rgb(247, 222, 0)
            max: 100
            show:
              legend_value: false
        apex_config:
          plotOptions:
            radialBar:
              offsetY: 0
              startAngle: -108
              endAngle: 108
              hollow:
              dataLabels:
                name:
                  show: false
                value:
                  show: false
              track:
                strokeWidth: 80%
                margin: 0
          fill:
            type: gradient
            gradient:
              shade: light
              type: horizontal
              shadeIntensity: 0.3
              inverseColors: false
              opacityFrom: 1
              opacityTo: 1
              stops:
                - 0
                - 33
                - 66
                - 100
          legend:
            show: false
          chart:
            height: 240
      - type: custom:mushroom-entity-card
        primary_info: state
        secondary_info: name
        icon_color: yellow
        layout: vertical
        card_mod:
          style: |
            ha-card {
              margin-top: -90px;
              width: 140px;
              margin-left: auto;
              margin-right: auto;
    card_mod:
      style: |
        ha-card { --ha-card-background: rgba(0, 0, 0, 0);
        mini-media-player-background-opacity: 0
        --ha-card-box-shadow: none; }
    cards:
      - square: false
        columns: 3
        type: grid
        cards:
            cards:
                series:
                  - entity: sensor.memory_use_percent
                    color: rgb(247, 8, 0)
                    max: 100
                    show:
                      legend_value: false
                apex_config:
                  plotOptions:
                    radialBar:
                      offsetY: 0
                      startAngle: -108
                      endAngle: 108
                      hollow:
                      dataLabels:
                        name:
                          show: false
                        value:
                          show: false
                      track:
                        strokeWidth: 80%
                        margin: 0
                  fill:
                    type: gradient
                    gradient:
                      shade: light
                      type: horizontal
                      shadeIntensity: 0.3
                      opacityFrom: 1
                      opacityTo: 1
                      stops:
                        - 0
                        - 33
                        - 66
                        - 100
                  legend:
                    show: false
                  chart:
                    height: 140
                primary_info: state
                icon_color: red
                layout: vertical
                card_mod:
                  style: |
                    ha-card {
                      margin-top: -57px;
                      width: 140px;
                      margin-left: -4px;
                      margin-right: auto;
            cards:
                series:
                  - entity: sensor.processor_use
                    color: rgb(0, 82, 247)
                    max: 100
                    show:
                      legend_value: false
                apex_config:
                  plotOptions:
                    radialBar:
                      offsetY: 0
                      startAngle: -108
                      endAngle: 108
                      hollow:
                      dataLabels:
                        name:
                          show: false
                        value:
                          show: false
                      track:
                        strokeWidth: 80%
                        margin: 0
                  fill:
                    type: gradient
                    gradient:
                      shade: light
                      type: horizontal
                      shadeIntensity: 0.3
                      opacityFrom: 1
                      opacityTo: 1
                      stops:
                        - 0
                        - 33
                        - 66
                        - 100
                  legend:
                    show: false
                  chart:
                    height: 140
                primary_info: state
                icon_color: blue
                layout: vertical
                card_mod:
                  style: |
                    ha-card {
                      margin-top: -57px;
                      width: 140px;
                      margin-left: -4px;
                      margin-right: auto;
            cards:
                series:
                  - entity: sensor.temperatura_processore_nuc
                    color: rgb(247, 124, 0)
                    max: 120
                    show:
                      legend_value: false
                apex_config:
                  plotOptions:
                    radialBar:
                      offsetY: 0
                      startAngle: -108
                      endAngle: 108
                      hollow:
                      dataLabels:
                        name:
                          show: false
                        value:
                          show: false
                      track:
                        strokeWidth: 80%
                        margin: 0
                  fill:
                    type: gradient
                    gradient:
                      shade: light
                      type: horizontal
                      shadeIntensity: 0.3
                      opacityFrom: 1
                      opacityTo: 1
                      stops:
                        - 0
                        - 40
                        - 80
                        - 120
                  legend:
                    show: false
                  chart:
                    height: 140
                primary_info: state
                icon_color: orange
                layout: vertical
                card_mod:
                  style: |
                    ha-card {
                      margin-top: -57px;
                      width: 140px;
                      margin-left: -4px;
                      margin-right: auto;
    card_mod:
      style: |
    cards:
        mode: vertical
        cards:
            series:
              - entity: sensor.cpu_speed
                color: rgb(255, 87, 34)
                max: 5
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 80%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 1
                    - 2.5
                    - 4
              legend:
                show: false
              chart:
                height: 240
            primary_info: state
            icon_color: deep-orange
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -90px;
                  width: 140px;
                  margin-left: auto;
                  margin-right: auto;
        card_mod:
          style: |
        mode: vertical
        cards:
            series:
              - entity: sensor.mariadb_database_size
                color: rgb(66, 245, 96)
                max: 5000
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 80%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 1500
                    - 3000
                    - 5000
              legend:
                show: false
              chart:
                height: 240
            primary_info: state
            icon_color: light-green
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -90px;
                  width: 140px;
                  margin-left: auto;
                  margin-right: auto;
        card_mod:
          style: |
  - type: entities
    entities:
      - entity: binary_sensor.backups_stale
        secondary_info: last-changed
      - entity: sensor.home_assistant_log_last_updated
        name: Ultimo Aggiornamento
    style: |
      ha-card {
    cards:
        primary: RIAVVIO
        secondary: ''
        icon: mdi:restart
        layout: vertical
        icon_color: red
        tap_action:
          action: call-service
          service: homeassistant.restart
          data: {}
          target: {}
        style: |
          ha-card {
        primary: SPEGNIMENTO
        secondary: ''
        icon: mdi:power
        layout: vertical
        icon_color: blue
        tap_action:
          service: hassio.host_shutdown
          data: {}
          target: {}
        style: |
          ha-card {
        primary: LOGS
        secondary: ''
        icon: mdi:alert-circle-check-outline
        layout: vertical
        icon_color: orange
        tap_action:
          action: url
          url_path: https://https://tarohomeassistant.duckdns.org:8123/config/logs
        style: |
          ha-card {
Hi, I am trying to set up this card but in case I paste code I see nothing in card only message: No visual editor available for type 'custom:config-template-card'
Many thanks for your help.
This card is 100% yaml only.
I understand, many thanks. But I had a problem that card was plain, nothing on it, but when I deleted all variables it is working:
- states[''sensor.disk_use_percent''].state
  - states[''sensor.homeassistant_version''].state
  - states[''sensor.disk_total''].state
  - states[''sensor.disk_use''].state
  - states[''sensor.memory_use_percent''].state
  - states[''sensor.processor_use''].state
  - states[''sensor.cpu_temperature''].state
Should I define it somewhere? Many thanks!
Can somebody help me to setup the background image >?
This is my config type: custom:hui-entities-card
title: ‘Gigabite Brix OS: Ubuntu 20.04.1 LTS’
show_header_toggle: ‘off’
style: |
ha-card { border-radius: 20px; }
entities:
  • type: custom:hui-vertical-stack-card
    cards:
    • type: horizontal-stack
      cards:
      • type: picture
        style: |
        ha-card {
        –paper-card-background-color: ‘rgba(0, 0, 0, 0.0)’;
        –ha-card-background: “rgba(0, 0, 0, 0.0)”;
        –ha-card-box-shadow: ‘none’;
        image: /local/NUC.specs.jpg
      • type: custom:button-card
        layout: icon_name_state2nd
        show_icon: true
        show_state: true
        styles:
        grid:
        - grid-template-columns: 50px auto
        icon:
        - padding: 20px 10px
        - height: 30px
        - width: 30px
        card:
        - ‘–ha-card-background’: rgba(0, 0, 0, 0.0)
        - ‘–ha-card-box-shadow’: none
        state:
        - padding: 0px 10px
        - justify-self: start
        - font-family: Roboto, sans-serif
        - font-size: 15px
        name:
        - padding: 0px 10px
        - color: var(–secondary-text-color)
        entity: sensor.cpu_temp
        name: CPU Temperature
        icon: mdi:fire
    • type: custom:mini-graph-card
      entities:
      • entity: sensor.processor_use
        height: 50
        line_width: 2
        font_size: 80
        hours_to_show: 4
        points_per_hour: 90
        show:
        icon: false
        extrema: true
        color_thresholds:
      • value: 28
        color: ‘#e74c3c
      • value: 15
        color: ‘#1db954
      • value: 0
        color: ‘#3498db
        style: |
        ha-card {
    • type: custom:bar-card
      title_position: inside
      name: ‘Disk usage: 500Gb’
      show_icon: true
      align: split
      columns: 1
      max: 100
      unit_of_measurement: ‘%’
      severity:
      • value: 50
        color: ‘#3498db
      • value: 75
        color: ‘#f39c12
      • value: 100
        color: ‘#e45e65
        style: |
        ha-card {
      cards:
        show_icon: true
        align: split
        columns: 1
        max: 100
        severity:
        • value: 50
          color: ‘#3498db
        • value: 75
          color: ‘#f39c12
        • value: 100
          color: ‘#e45e65
          style: |
          ha-card {
        show_icon: true
        align: split
        columns: 1
        max: 100
        severity:
        • value: 50
          color: ‘#3498db
        • value: 75
          color: ‘#f39c12
        • value: 100
          color: ‘#e45e65
          style: |
          ha-card {
      height: 20
      line_width: 2
      font_size: 70
      hours_to_show: 168
      points_per_hour: 1
      show:
      extrema: true
      fill: true
      style: |
      ha-card {
      border-radius: 5px;
      entities:
      • sensor.cpu_temp
        color_thresholds:
      • value: 90
        color: ‘#3498db
      • value: 120
        color: ‘#f39c12
      • value: 150
        color: ‘#E45E65
    • entities:
      • entity: sensor.time_of_day
        name: HA Docker herstart
      • entity: sensor.versie
        name: Home Assisten version
      • entity: sensor.last_boot
        show_header_toggle: false
        type: entities
        style: |
        ha-card {
It would be a bit easier if you post the code in code tags as described in this post at the top of each forum.
I have exactly the same problem do you find a solution ?
Tell me please. Is it possible to get process download data for individual applications installed from Home Assistant.
I’m hoping someone can help me troubleshoot getting my ProxMox sensors to show up. It seems pretty strange that they worked initially, but then some kind of update stop them from being discovered. I’ve even uninstall mqtt and the mosquitto broker addon, and reinstalled both yet they still do not report.
I setup the monitor from post 42 by Hs82H, and after few tweaks for python3 got it working. The script seems to run, no errors. And I then check with mqtt explorer and see the sensor results showing. But homeassistant still won’t show them
This what I see with mqtt explorer.
I see the sensors, but it is also reporting a status of offline? The mosquitto broker is running and I see the connections from Proxmox. And the mqtt integration is also running. Both the mqtt integration and proxmox are both set for topic prefix of homeassistant as well. And the mqtt integration has discovery turned on.
From my understanding the mqtt should be picking up the devices automatically?
Any help or trouble shooting is greatly welcomed.
Thanks,
PT
slight change of tack, but I spotted this today, added to my system, and 5 minutes later have everythingg working perfectly. Super easy way to pull all your proxmox stats, and your VM/LXC stats.
dougiteixeira/proxmoxve: Proxmox VE Custom Integration Home Assistant (github.com)
Well, I couldn’t get HACS to find the repository. But a quick manual install and up and running with that integration in 5 minutes. And its great that I can see all system stats and also the VMs. I also run HomeAssistant on the ProxMox as a VM and can even see that information there.
But I would still like to try and troubleshoot why the MQTT script is sending the data, but not showing up in HA.
Could you share the yaml for this view? I like how the bar and graph look combined!
Hello, really nice, please can you post your code for the “Synology” ?
I’m sorry, not using this anymore and think my code has gone
