Hello everyone. Yesterday Home Assistant seemed to have problems and so I decided to re-record the image. Since I couldn’t access the ha connect a monitor to see what the problem was and I saw that I didn’t have an ip. Restart router, mesh and I still have the same problem. change the nuc of place in case it was the cable and neither. What could I try? Thank you
I solved the problem with this command but when I unplug the NUC I have to run that line again and the problem is that only on one of the TVs I have I can see what is happening with home aassistant.
network update eno1 --ipv4-method auto
