I’m not very computer savvy, so take at easy on me.
Here is the info let me know if anything else is required.
Intel NUC 12 PRO mini-PC NUC12WSKI50YC, i5-1240P
PCIe x4 Gen 4: M.2 22x80 (key M) used for SSD
PCIe x1 Gen 3: M.2 22x42 (key B) empty
PCIe x1: M.2 22x30 (key E)
Home Assistant is on Odroid
I have a Coral mini PCIe card and thought there might be an adaptor card for the key b, but the case is very compact and I had a hard time finding an adaptor that would work on any device.
Can swap the Intel® Wi-Fi 6E AX211 (Gig+) M.2 E card with a new coral M.2 E card? This is the only one I have access to, if this works might change it for a dual if I’m lucky enough to find one. Any issues removing the WiFi card? For now it will only be used for frigate, maybe as I learn I’ll add more. Using ethernet so no need for Wifi.
Thank you
