I’m the owner of a Nuki Smartlock 3.0. Pro with the WIFI incorporated.
Will be great to manage it from Home Assistant in the Nuki Assistant
@sebastienserre make sure you vote on your feature request as well.
There’s hope that the latest version which has MQTT support will make it easier to integrate: https://support.nuki.io/hc/en-us/articles/12947926779409-MQTT-support
Hello.
I am waiting for a Nuki 3 Pro.
I am already searching the best way to add it to HA. I think MQTT its the best one.
It will work as per the documentation on https://support.nuki.io/hc/en-us/articles/12947926779409-MQTT-support ? I hope so.
Confirm this works with MQTT in the Nuki 3.0 Pro
Not necessarily. I have an open MQTT bridge for which I do not care much if someone got access (it is limited to my LAN but otherwise open).
Because of that I set up Nuki’s MQTT not to allow opening the door. I use the API in on of my applications and it is much better because it is authenticated.
I would be thrilled to see a Nuki integration via the HTTPS protocol.
