Nuki automation
Is there a way to do something (automation) as soon as nuki gets unlocked? For example, as soon nuki gets unlocked turn the light on.
The only function i can find in the nuki integration is lock and unlock the smart lock.
You can trigger an automation as the state changes from ‘locked’ to ‘unlocked’
Thanks for your answer. The status needs mostly around 30 seconds to change its state. Is there a way to speed up that status change? Ifttt for example shows immediately when nuki gets locked or unlocked.
Sometimes in home assistant it shows that nuki went offline. But it isn‘t offline. Is there a problem with the nuki integration?
