I am trying to use the “official” Nuki integration Nuki - Home Assistant and I am unable to get this working.
Adding the integration always ends with “Aborted” and that’s it.
I am using a Nuki 1 with a Nuki Bridge. The app itself works fine. I also tested the access token a 100 times but I enter the right one, as soon as I enter a different one I also get an authentication error.
So I must assume that the integration setup process or even the integration is broken.
I know that there is another integration GitHub - kvj/hass_nuki_ng: Better support for Nuki devices in the Home Assistant but I would like avoid using external sources as good as possible, even though the featureset of nuki_ng is much better than the HA integration.
I also collected some other people having one or the other issue with the integration. I also see that there are some code changes on the github repo of the integration, so lets see how far we get with the community before raising an issue on github.
- Including Nuki Bridge does not work
- Nuki integration vs nuki api
- Nuki integration with hardware bridge fails
I found some github issue too. I reference the latest one, should be enough
