Nuki lock and automation HELP
Hi, i have a nuki lock who I can see in de home GUI. Now I want too make a automation, dat every evening @ 10PM the lock goes te lock en open @ 8AM in morning again. When I’m in automation gui and I want too make this automation I can only add een device and not a identity, sinds my lock is only a identity I can select it. I hope you can help me with a solutions too this problem. Thanks in advance!
I have a nuki automation which sounds similar. In the GUI the the action is:
where back_door is the name you have given to your Nuki lock.
Incidentally, it’s much simpler to have two automations, one to lock and one to unlock.
Thnx, that did the trick !!
