I’m trying to set up my brand new nuki smart lock, but I can’t make it work, I enabled the API and retrieved the token and in my configuration I have this:
lock:
- platform: nuki
host: 192.168.x.x
port: 8080
token: !secret nuki_token
but in the logs i receive the following message:
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.x.x', port=8080): Max retries exceeded with url: /info?ts=2020-11-25T22:02:33Z&rnr=235xx&hash=e177b8001e86f98(Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6f0b7988>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
this seems like a Bridge problem, I’m using and old HTC m8 with the bridge app,
but if i use the following command
time curl -v "http://192.168.x.x:8080/lockState?token=tokenSixDigits&nukiId=nukiId" | python -m json.tool
i receive the correct response
{ [73 bytes data]
100 73 100 73 0 0 15 0 0:00:04 0:00:04 --:--:-- 15
* Connection #0 to host 192.168.x.x left intact
"batteryCritical": false,
"state": 3,
"stateName": "unlocked",
"success": true
So im not sure what is happening, i don’t know why HA can’t connect any suggestion?
Debug info:
HA Version 0.118.3
HassOS 4.17
Supervisor version 2020.11.0
Any help will be appreciatedthanks a lot!!!
