One of my flows was checking user_id to see if a light was switched on by hassio or a human user with his mobile app.
I ran a bunch of updates lately so I’m not sure it’s Node-RED’s one who broke getting this info, but I do no more have the user_id
No mater if the order comes from a desktop browser or the mobile app.
Running Home Assistant surpervised on a Raspberry Pi 4, Ubuntu 19 in Docker.
Supervisor 243
Ubuntu 19.10
Docker version 19.03.12
Node-RED 7.1.1>
20-09-14 21:01:15 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:62711 ssl:default [Connection refused]
20-09-14 21:01:30 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
20-09-14 21:01:30 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.APPLICATION’ start 3 add-ons
20-09-14 21:01:31 INFO (SyncWorker_1) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-configurator with version 5.0.0
20-09-14 21:01:33 INFO (SyncWorker_3) [supervisor.docker.addon] Start Docker add-on esphome/esphome-hassio-armv7 with version 1.15.0
20-09-14 21:01:34 INFO (SyncWorker_6) [supervisor.docker.addon] Start Docker add-on hassioaddons/node-red-armv7 with version 7.1.1
20-09-14 21:01:34 INFO (MainThread) [supervisor.api.security] /host/info access from 15ef4d2f_esphome
20-09-14 21:01:36 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_nodered
20-09-14 21:01:38 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_nodered
20-09-14 21:01:39 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-09-14 21:01:39 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-09-14 21:01:39 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-09-14 21:01:39 INFO (MainThread) [supervisor.host.info] Update local host information
20-09-14 21:01:39 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-09-14 21:01:39 INFO (MainThread) [supervisor.host.services] Update service information
20-09-14 21:01:40 INFO (MainThread) [supervisor.host.network] Update local network information
20-09-14 21:01:40 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-09-14 21:02:07 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
20-09-14 21:02:07 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
20-09-14 21:02:07 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
20-09-14 21:02:48 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:62711 ssl:default [Connection refused]20-09-14 21:23:50 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:0 is not WSMsgType.TEXT
20-09-14 21:23:50 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
20-09-14 21:23:55 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
20-09-14 21:23:55 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
20-09-14 21:23:55 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
