As mentioned in another thread I have kep my old HA running with some old versions till I decided to finally upgrade hardware then did an update of OS etc. In doing so i found a lot has changed and decided to start from scratch.
On my olf Lovelace I used to have a slider that showed one decimal place for a tempreture set point. It would have been configured in YAML
So trying to keep things kleen this time I found the helper UI and creaed a helper number BUT cant get it to use 0.1 as in 21.5 or 23.1. It does whole numbers.
So do I have to make those in the config file to achieve that? ALso whilst on that, I also created a couple of toggle helpers. How do you set the restore state etc?
An after thought it a may have copied your image… I am remoting in to my server.
It doesn’t have the step size? When I took the image above I was so used to it not being visible that I didnt see it was there. I went back into that helper and its not there.
Yes this is strange. I am starting to second guess myself. Thanks heaps 123. So far though so good. I like all the improvements I had been missing out on.
Glad to see I am not totaly loosing it. I will go and create a couple the old way with Yaml for what I need but I do notice in myself rebuilding my system I learnt so much from my system over the last few years that I nearly know what I need as I go instead of adding and adding and testing. I use node-red as my automations and its even looking a lot cleaner.
My partner (I have mentioned this before) has multiple personality disorder and I use the system to help her. I used to have a lot of reminders played over the text to speech and doing this rebuild I have left a lot out. She asked me yesterday to put a few of the ones back in so I know the system is well worth it as is all your inputs and help
Same here. I can use 1 and 0.1 as “Step size”, but not 0.01 or smaller. Also I cannot write decimal numbers from info view without clicking “increase/decrease buttons”. see e.g.
