I am trying to use a number as user input from HA and use the value within an ESPHome program. However, it seems as the value, after set with either the HA GUI (Integrations → ESPHome device → input field) or the service number.set, is only updated in the lambda variable “x” but not as the actual state.
The config is as below:
number:
name: $device_name Light 0
entity_category: config
mode: box
min_value: 1
max_value: 6
step: 1
set_action:
then:
- lambda: |-
byte symbol = 2 * x;
symbol += 20;
if (id(light0).state) {
symbol += 1;
id(disp1).send_command_printf("Lights.light0.pic=%i", symbol);
ESP_LOGW("main", "Number set to: %f (%f)", id(light0_symbol).state, x);
The symbol code is not relevant here, but the bottom line in the lambda shows the challenge. Whenever the value is changed, I receive the following in the log:
14:42:45][D][number:010]: 'nspanel-dev Light 0' - Setting
[14:42:45][D][number:029]: Value: 2.000000
[14:42:45][W][main:807]: Number set to: 1.000000 (2.000000)
[14:42:55][D][number:010]: 'nspanel-dev Light 0' - Setting
[14:42:55][D][number:029]: Value: 3.000000
[14:42:55][W][main:807]: Number set to: 1.000000 (3.000000)
[14:45:20][D][number:010]: 'nspanel-dev Light 0' - Setting
[14:45:20][D][number:029]: Value: 2.000000
[14:45:20][W][main:807]: Number set to: 1.000000 (2.000000)
[14:45:27][D][number:010]: 'nspanel-dev Light 0' - Setting
[14:45:27][D][number:029]: Value: 2.000000
[14:45:27][W][main:807]: Number set to: 1.000000 (2.000000)
When I read the value later on with id(light0_symbol).state it is always 1.
What am I missing? Why is not the “actual” state updated but only x variable in the lambda part?
I have tried to implement that in the code with a check that the call is only made if the state of the number object is different than the new value (x). The intention of this is to avoid an infinite loop, as the call will update the value if I understand it correctly. However, the result is a infinite loop.
The code:
mode: box
min_value: 1
max_value: 6
step: 1
set_action:
then:
- lambda: |-
if (id(light0_symbol).state != x) {
auto call = id(light0_symbol).make_call();
call.set_value(x);
call.perform();
symbol += 20;
symbol += 1;
I think that is the easiest approach. However, I think it’s a pity to not be able to use the input number (or input select, same issue there). I want to use it for a setting, and now the actual value cannot be seen in the same selector as where the setting is saved…
