Number variable in string - convert to string in action
Hi there,
I am currently trying to write a small script for HomeMatic on-for-timer. I know the service I found is working, as executing it manually works. But when I try to get it into a script it starts to fail.
To be exact: It also works in the script, as long as I don’t put the ON_TIME to a variable and hardcode the value. As soon as I set a template variable, it does not work any more.
When digging around in the script debugger, I found one notable difference:
When setting the variable manually, the script outputs ON_TIME as '10' (with quotes).
When I do the same with a variable, it leaves the quotes away.
Now question - how do I always get the quotes?
I already tried to make on_seconds a string - that also didn’t change anything. That’s probably a totally simple reason :frowning:
on_for_timer:
  alias: On for timer
  fields:
    entity_id:
      description: 'entity_id'
      example: 'switch.wz_fernseher'
      selector:
        entity:
    on_seconds:
      description: 'Seconds after which the device will be shut down again'
      selector:
        number:
  sequence:
    - service: homematic.put_paramset
        address: "{{ state_attr(entity_id, 'id') }}:1"
        interface: rf
        paramset:
          ON_TIME: "{{ on_seconds | string }}"
          STATE: true
        paramset_key: VALUES
Thanks for any help!
Matthias
I’ve found a solution - a very hacky solution.
To force Home Assistant to make a string out of the result, I just prepended a 0. That way Home Assistant now evaluates ON_TIME to ON_TIME: '010' - which HomeMatic can parse. Nobody cares about octal values (which the 0 actually would trigger, so it seems to be fine).
However - is there a better solution? This currently very much looks like a bug to me …
Matthias
Hi @klassm - Did you ever find a “real” solution? I am running into something very similar.
This hard coded example works:
roomba_clean:
  alias: Roomba - Clean
  mode: single
  sequence:
    - service: vacuum.send_command
          entity_id: vacuum.roomba
          command: start
          params:
            pmap_id: XXXYYYZZZ
            regions:
              - region_id: '9'
                type: rid
            user_pmapv_id: AAABBBCCC
But it fails when I use a variable for region_id. I think the Roomba expects region_id to be a string. My hard coded example works because the 9 is within single quotes:
region_id: '9'
I tried forcing the value to be a string using both methods below but neither worked:
region_id: "{{ region_id | string }}"
region_id: '"{{ region_id }}"'
Thoughts?
Nope, I am still with this weird solution -.-
Thanks @klassm. I ended up using your same “0” trick. It is dumb, but it works! I appreciate you sharing it.
              command: start
              params:
                pmap_id: "{{ pmap_id }}"
                regions:
                  - region_id: "0{{ region_id | string }}"
                    type: "{{ type }}"
                user_pmapv_id: "{{ user_pmapv_id }}"
I found this message when I was also looking to convert an integer to a string, and I did manage to use the “0” trick mentoned above to convert integer ‘9’ to string ‘09’, but it didn’t help when I wanted to convert integer ‘13’ as it came out as ‘013’, and the leading zero was now a problem.
I did find Jinja provides the “~” (tilda) operand to add integers and strings. I found it in this post python - casting ints to str in Jinja2 - Stack Overflow and it’s also explained in this guide Template Designer Documentation — Jinja Documentation (3.1.x).
Posting in case this helps other people who were stuck like I was !
{{ "{:02d}".format(your_var) }}
Thanks @Didgeridrew ! This may help solve another problem I now have !
