Number: vs Globals:
I’ve been using Globals extensively in a project and came across the number: component (don’t know how I’d missed it).
Mostly, I use globals to store values from the HA front end that change with automations triggered from value changes in sensor components.
Other than shifting the automation part to the number:, what am I missing vs using globals?
I’m not quite seeing the differences/benefits the change could make.
Probably because it is very new. Only released in 1.20.0.
I’m trying to use number:, as below, but get an error:
        number.set:  [source /config/esphome/feeder.yaml:456]
          expected float.
          value: return ((id(on_board).now().minute) + (id(on_board).now().hour * 60))
time:
  - platform: ds1307
    update_interval: never
      - number.set:
          value: 'return ((id(on_board).now().minute) + (id(on_board).now().hour * 60)) '
I’ve tried it several ways with similar results. I suspect that this is due to minute and hour being of type int. Or maybe even str.
The docs seem to indicate that number: can only be of type float.
Is there a way around this?
