I need a trigger for a numeric value, that goes off when the state value is above a specific value, but ONLY if the previous value is 0 (zero).
The numeric_state does not allow ‘from:’.
How do I achieve this?
Use from zero as the trigger, and the condition is over specified number.
Thanks. Will test both this and the other way around
automation:
- alias: test1
- platform: numeric_state
entity_id: sensor.random
above: '1'
condition:
- condition: state
- service: notify.telegram
data_template:
message: "Test 1 - Sensor has raised above {{ trigger.to_state.state }} {{ trigger.to_state.attributes.unit_of_measurement }}."
- alias: test2
- platform: state
condition:
- condition: numeric_state
above: '1'
data_template:
message: "Test 2 - Sensor has raised above {{ trigger.to_state.state }} {{ trigger.to_state.attributes.unit_of_measurement }}."
Because condition doesn’t support from
That makes sense.
From the documentation only state:
is supported, I guess
I have been experimenting the last few days. And have not found a solution yet. Probably because the sensor can have both 0
as 0.0
(mind the decimal) as a value. Because of this, I think, the from:
trigger does not work.
This happens with the Buienradar sensor
What is working, of course, is a notification when not using a from trigger and not using a condition:
- platform: buienradar
latitude: !secret home_latitude
longitude: !secret home_longitude
timeframe: 30
monitored_conditions:
- precipitation_forecast_average
automation:
- alias: Rain Alarm
- platform: state
entity_id: sensor.buienradar_precipitation_forecast_average
data_template:
title: "Regenalarm"
message: "De komende 30 minuten wordt {{ trigger.to_state.state }} {{ trigger.to_state.attributes.unit_of_measurement }} neerslag verwacht"
I am now trying a platform: template
trigger.
I use forcast_total
, which because of the low trigger level only triggers if it has been 0 before;
entity_id: sensor.br_precipitation_forecast_total
above: 0.01
By the way, if the problem is caused by 0 and 0.0 can’t you just round the result within your template? Otherwise you can set and input boolean when it’s zero and use that as a condition.
Do you use the numeric state as a trigger or condition?
Rounding it means creating a value template. I think I can’t use the trigger.to_state.state any longer.
As a trigger.
