Hi All,
I have this challenge of which I actually did not expect it to be a challenge.
The thing I want is to have a numeric state trigger that triggers on a value below or above a value of a helper value (input_number) for a certain time.
The first part is easily done with a relatively simple template trigger, for example:
{{ states('sensor.power')|int > states('input_number.slider_1')|int }}
The challenge is to have it work like a numeric state so you can basically say “state above value X for Y time”. I expected to be able to use the template option, but a manually entered value in above/below is required.
Is there anyone that:
- knows if the template is also part of the for condition (my test did not confirm that)?
- knows if it is part of, what is the correct syntax?
- has another way of achieving this goal?
