Hi, I want to switch a floor heating automatically on if the highest temperature of the day is below 20. Unfortunately it does not work, the switch is always turned on. any hints?
- id: Fussbodenheizung_Bad_einschalten
alias: Fussbodenheizung_Bad_einschalten
- at: 06:00:00
platform: time
- entity_id: group.alle
platform: state
to: home
condition:
- after: 05:59:59
before: '22:00:00'
condition: time
- condition: state
state: home
- condition: state
entity_id: input_boolean.heizperiode
state: 'on'
- condition: state
entity_id: input_boolean.urlaub
state: 'off'
- below: '20'
condition: numeric_state
entity_id: sensor.dark_sky_daytime_high_temperature_0d
value_template: '{{ states("sensor.dark_sky_daytime_high_temperature_0d") | float }}'
- entity_id: switch.badezimmer_fussbodenheizung
service: switch.turn_on
initial_state: 'on'
Further to what Tom said, I recommend that you create an input_boolean.test_bit and just have it lying around. Then when you need to test actions and conditions you can insert it as a trigger (remember to remove it or 90% of your automations will all fire) this can be done on a reload (no restarts required).
Testing Triggers is way more tricky
