why does this not trigger?
alias: Pool pumpe Besked ved overforbrug kwh
description: ''
- platform: numeric_state
entity_id: sensor.forbrug_idag
above: '0.1'
below: '0.6'
condition: []
- service: notify.mobile_app_rhmobil
message: Pool pumpe bruger for meget strøm
- service: notify.gmail
mode: restart
For this automation to work the sensor value need to go from a value below 0.1 to above it or go from above 0.6 and below, so it needs to cross the values gives.
So it could be that this sensor value stays inbetween 0.1 and 0.6 from day to day for your case as it is a sensor for the daily power consumption for your pool pump. Is this a sensor you have made yourself? If so you should perhaps make an automation that zeros it out at midnight.
thanks - it goes to zero every night
so i hope this will work tomorrow - when it goes for 0 to 0.5 ,this will trigger?
You needn’t wait until tomorrow, under developer tools/states you can manually set a value out of the triggering range.
Set 1 for example and click set state. After that, set a value whithin the triggering range and it should work.
The actual value of the sensor will automatically revert to the readings as soon as the sensor updates.
If you want it to trigger anyways despite not surpassing those thresholds, this would do it.
description: ''
- platform: state
condition:
- condition: template
value_template: "{{ 0.1 <= states('sensor.forbrug_idag')|float <= 0.6}}"
DOH! :- ) you’re so right … it worked… thanks for your time and help!
