I have defined template to read the 30 minute electricity export values over defined time. It use a known and proven HACS sensor(sensor.agile_export_rate) gets dict of todays 30 mins prices. The sorts them and determines if any the export prices are above my target profit. input_number.target_profit_am
Within the Developer tools it works perfectly and returns the count as expected and there are no errors generated etc.
However, when use the sensor in any Lovelace card i get “Unavailable” but, if I use the “States” tool and set a value manually it displays correctly. I had thought that the line {{ {{ ns.count }} would return the value I see the Developer tool.
I share the code in the hope someone can show me the errors of the ways…
sensors:
discharge_for_profit_am:
friendly_name: “AM Profit Slots”
value_template: >-
{% set ns = namespace(count = 0) %}
{% set rates_today = state_attr(‘sensor.agile_export_rate’, ‘rates_today’) %}
{% if rates_today | count > 0 %}
{% set sorted_rates_today = dict((rates_today.items() | list)[52:102]) | dictsort %}
{% if sorted_rates_today | count > 0 %}
{% set time_values = sorted_rates_today | map(attribute=‘0’) | list %}
{% for time in [‘05:00’, ‘05:30’, ‘06:00’, ‘06:30’, ‘07:00’, ‘07:30’, ‘08:00’, ‘08:30’, ‘09:00’, ‘09:30’] %}
{% if time in time_values %}
{{ time }}: {{ sorted_rates_today | selectattr(‘0’, ‘eq’, time) | map(attribute=‘1’) | list | first }}
{% set rate_value = sorted_rates_today | selectattr(‘0’, ‘eq’, time) | map(attribute=‘1’) | list | first %}
{% if rate_value > states(‘input_number.target_profit_am’) | float / 100 %}
{% set ns.count = ns.count + 1 %}
{{ ns.count }}
{% endif %}
{% else %}
{{ time }} #time out of range
{% endif %}
{% endfor %}
{% else %}
{% set ns.count = 0 %} # No rates found between in the morning
{% endif %}
{% else %}
{% set ns.count = 0 %} # Rate information is unavailable.
{% endif %}
{{ ns.count }}
