nat
(phoniclynx)
November 14, 2021, 1:23am
1
I have a power meter that is connected to a washing machine. Whenever the power meter falls off the WiFi ti seems to trigger an automation which seems to be giving LOTS of false positives. I’m not sure how to fix this. It is causing a lot of angst in the house because this notification goes off several times when it shouldn’t be.
alias: State - Washing Machine
description: ''
- platform: numeric_state
above: '5'
for:
hours: 0
minutes: 0
seconds: 0
milliseconds: 0
entity_id: sensor.washing_machine_dryer_current_consumption
for:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
below: '5'
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
entity_id: input_boolean.washing_machine
- conditions:
sequence:
- service: input_boolean.turn_off
- service: input_datetime.set_datetime
entity_id: input_datetime.washing_machine_finished
timestamp: '{{ now().timestamp() }}'
- service: notify.mobile_app_denise_mobile
message: The washing machine has finished
title: Washing Machine
- service: notify.mobile_app_nathaniel_mobile
default: []
mode: single
When the Kasa tplink drops off the wifi, after 1 min it triggers the even that it’s gone under 5W when it never actually went over 5W when it went off line.
These two monitors sit next to each other and they went off at the same time:
tom_l
November 14, 2021, 1:46am
2
Add conditions to exclude the trigger.to_state
and trigger.from_state
being 'unavailable'
Is the state of “sensor.washing_machine_dryer_current_consumption” turning to “unavailable” when the wifi drops?
If so, you can add another condition with a trigger variable after the trigger condition
- conditions:
- condition: template
value_template: "{{ trigger.from_state.state not in ['unavailable', 'unknown'] }}"
sequence:
nat
(phoniclynx)
November 14, 2021, 1:52am
5
I changed it to this:
- choose:
- conditions:
sequence:
- conditions:
- condition: "{{ trigger.from_state.state not in ['unavailable', 'unknown']}}"
sequence:
and I seem to get the error message :
Message malformed: required key not provided @ data['action'][0]['choose'][1]['sequence']
Sorry, I’m on a tablet and the spacing got messed up when I pasted it… the new condition needs to line up with the original one… it’s fixed above.
nat
(phoniclynx)
November 14, 2021, 1:57am
7
haha the errors are getting longer:
Message malformed: Unexpected value for condition: '{{ trigger.from_state.state not in ['unavailable', 'unknown']}}'. Expected and, device, not, numeric_state, or, state, sun, template, time, trigger, zone @ data['action'][0]['choose'][1]['conditions'][1]
I’m sorry, I messed up the shorthand notation of the template condition in the Choose action…
- choose:
- conditions:
sequence:
- conditions:
- "{{ trigger.from_state.state not in ['unavailable', 'unknown']}}"
EDITED to remove misleading information and add shorthand notation resource. (Translation: I’m an idiot who read the docs, misunderstood the format, then blamed it on the Choose action… )
nat
(phoniclynx)
November 14, 2021, 2:19am
9
ok… that workes far better… cheers…now to see what it does when it falls off the WiFi
123
(Taras)
November 14, 2021, 5:55am
10
I almost always use shorthand notation in a choose
’s conditions
- choose:
- conditions: "{{ trigger.id == 'On' }}"
sequence:
- conditions:
- "{{ trigger.id == 'Off' }}"
sequence:
I stand corrected… for some reason I was doing it like this ( ):
- conditions:
- condition: "{{ trigger.id == 'On' }}"
