Hello dear community,
Can someone tell me why I can’t swap these two entities?
I can’t find “Raumklima Schlafzimmer” in the lower column.
If I exchange it in the Yaml, there is also a mistake.
I hope you can help me…
Greetings, Marcel
Greetings, Marcel
This is a guess since you have not shared the YAML, which would give actual entity details…
A climate entity is allowed in the entity_id
configuration variable because climate entities have numeric attributes which could be used in a Numeric state trigger or condition. But the comparison variables, above/below
, can only access the entity’s state.
Thank you very much for the reply.
I found the error.
You are right. I had to create a template.
Now it works.
Greetings, Marcel
