I’ve divided my Zigbee network into two smaller subnetworks. Initially, everything worked fine, but most battery-operated devices on the new subnetwork suddenly became unavailable in HA. The autodiscovery and state messages both look fine (samples included below) and the Z2M dashboard shows the devices and all state attributes with updates.
This persists across reboots of HA, Z2M, and the broker. I’ve also tried reloading the MQTT integration multiple times. If I subscribe to the state topic in the MQTT integration page, I see the state messages appear.
I’m running HA 2024.12.5 and Z2M 1.42.0. I’ve been struggling with various attributes and sensors dropping out for a while, which I thought was related to my original network size (about 70 Zigbee devices, which I didn’t think was that huge).
Sample state message
zigbee2mqtt-upper/Cat's office temperature {"battery":90,"humidity":40.1,"last_seen":"2024-12-29T13:01:44-05:00","linkquality":105,"power_outage_count":76,"pressure":998.7,"temperature":17.42,"voltage":2985}
Sample discovery message
homeassistant/sensor/0x00158d000804b856/temperature/config {"availability":[{"topic":"zigbee2mqtt-upper/bridge/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt-upper/Cat's office temperature/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"configuration_url":"https://cherry.woohouse.world/zigbee-upper/#/device/0x00158d000804b856/info","identifiers":["zigbee2mqtt_0x00158d000804b856"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"Cat's office temperature","via_device":"zigbee2mqtt_bridge_0x00124b002e0e16a7"},"device_class":"temperature","enabled_by_default":true,"object_id":"cat's_office_temperature_temperature","origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt-upper/Cat's office temperature","unique_id":"0x00158d000804b856_temperature_zigbee2mqtt-upper","unit_of_measurement":"°C","value_template":"{{ value_json.temperature }}"}
Note that while the sample messages I’ve posted do include an apostrophe, most of my devices don’t have any such punctuation and still have this problem.
Appreciate any help on debugging this!
