I recently upgraded NUT add-on from the Add-on store to (Network UPS Tools) 0.2.1 and it stopped working with this error:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] nut: applying...
[fix-attrs.d] nut: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Network UPS Tools
Manage battery backup (UPS) devices
Add-on version: 0.2.1
You are running the latest version of this add-on.
System: HassOS 4.12 (armv7 / raspberrypi4)
Home Assistant Core: 0.113.3
Home Assistant Supervisor: 235
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nut.sh: executing...
[21:22:12] INFO: Setting mode to netserver...
[21:22:13] INFO: Generating /etc/nut/upsd.users...
[21:22:13] INFO: Configuring user: homeassistant
[21:22:14] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[21:22:17] INFO: Configuring Device named zinto1000...
[21:22:17] INFO: Starting the UPS drivers...
Error relocating /usr/sbin/upsdrvctl: __select_time64: symbol not found
Error relocating /usr/sbin/upsdrvctl: __difftime64: symbol not found
Error relocating /usr/sbin/upsdrvctl: __gettimeofday_time64: symbol not found
Error relocating /usr/sbin/upsdrvctl: __stat_time64: symbol not found
[cont-init.d] nut.sh: exited 127.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
s6-ftrigrd: fatal: unable to sync with client: Broken pipe
s6-svwait: fatal: unable to ftrigr_startf: Operation timed out
[s6-finish] sending all processes the TERM signal.
REFRESH
Do you have any idea about how to solve it?
