I just set up my NUT integration with my APC-2200 and I would like to get more states than the default integration gives me. According to the NUT doc, it can support the following:
battery.alarm.threshold | 0 |
battery.charge | 089.0 |
battery.charge.restart | 00 |
battery.date | 01/10/04 |
battery.packs | 000 |
battery.runtime | 21180 |
battery.runtime.low | 120 |
battery.voltage | 52.95 |
battery.voltage.nominal | 048 |
driver.name | apcsmart |
driver.parameter.pollinterval | 2 |
driver.parameter.port | /dev/ttyS0 |
driver.version | 2.2.0- |
driver.version.internal | 1.99.8 |
input.frequency | 50.00 |
input.quality | 00 |
input.sensitivity | H |
input.transfer.high | 253 |
input.transfer.low | 196 |
input.transfer.reason | T |
input.voltage | 000.0 |
input.voltage.maximum | 000.0 |
input.voltage.minimum | 000.0 |
output.voltage | 228.1 |
output.voltage.nominal | 230 |
ups.delay.shutdown | 020 |
ups.delay.start | 000 |
ups.firmware | 80.14.I |
ups.id | UPS_IDEN |
ups.load | 000.0 |
ups.mfr | APC |
ups.mfr.date | 01/10/04 |
ups.model | SMART-UPS 2200 |
ups.serial | YS0402211565 |
ups.status | OB |
ups.temperature | 024.7 |
ups.test.interval | 1209600 |
ups.test.result | NO |
How can I manually add these entities?
