NUT APC UPS connected with AP9619 network card
well…
You have to configure the access controls. Everything is blocked by default in the new FW, even if snmp v1 is enabled.
so: v1 is working, v3 is failing, but also with snmpwalk - I’ll dig into it.
I did dig into it and what should I say… I’ll switch to the native SNMP integration and hack down OIDs manually. No additional tool with fishy configs.
Here’s my solution: Get data from APC Smart + Network Management Card via SMTP - #22 by man55
I used the iReasoning MIB browser and looked for the appropriate values from the APC PowerNet MIB.
(don’t forget to add a .0 at the end)
Thanks for the script. Would you have any suggestion of how to edit the YAML for an additional APC UPS so the sensor information would differentiate between (2) devices?
Hello…
All you need to do is renaming the sensors like _1 and _2 and adjust the IP addresses to each ups…
