NUT challenge for HA
I want to seek for help of wiser people :slight_smile:
I have Qnap (Ts251A) with 8Gb connected via usb with UPS Cyberpower UT850EG (through USB connection - only available thing in Control Panel).
Also on Qnap in VM there is HA (with another IP which is whitelisted)
So i try to use NUT but cannot connect to UPS.
Tried several drivers but nothing that can help. After initiating the add-on stops with error.
I added followings in configuration file
devices:
  - config: []
    driver: usbhid-ups
    port: auto
mode: netserver
shutdown_host: "false"
users:
  - actions: []
    instcmds:
      - all
    password: "123456"
    username: qnapups
i_like_to_be_pwned: "true"
but logs says:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
 Add-on: Network UPS Tools
 Manage battery backup (UPS) devices
 Add-on version: 0.11.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 8.5  (amd64 / qemux86-64)
 Home Assistant Core: 2022.8.7
 Home Assistant Supervisor: 2022.08.6
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/02-set-timezone.sh
[22:55:03] INFO: Configuring timezone
cont-init: info: /etc/cont-init.d/02-set-timezone.sh exited 0
cont-init: info: running /etc/cont-init.d/nut.sh
[22:55:04] INFO: Setting mode to netserver...
[22:55:04] INFO: Generating /etc/nut/upsd.users...
[22:55:05] INFO: Configuring user: qnapups
[22:55:08] INFO: Configuring Device named qnapups...
[22:55:08] INFO: Starting the UPS drivers...
Network UPS Tools - Generic HID driver 0.41 (2.7.4)
USB communication driver 0.33
No matching HID UPS found
Driver failed to start (exit status=1)
Network UPS Tools - UPS driver controller 2.7.4
cont-init: info: /etc/cont-init.d/nut.sh exited 1
cont-init: info: running /etc/cont-init.d/nutclient.sh
cont-init: info: /etc/cont-init.d/nutclient.sh exited 0
cont-init: warning: some scripts exited nonzero
s6-rc: warning: unable to start service legacy-cont-init: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Can anybody have an idea ?
