NUT component not working
I used to have my NUT component set up and working so I could monitor things like voltage, charge, and power draw.
After an update to home assistant, all I see is
“NUT Sensor has no data, unable to set up”
and
“Platform nut not ready yet. Retrying in 180 seconds.”
However, if I run uspc -l, I do get all my values, so the server is working, home assistant just isn’t seeing it.
Nut is working fine for me on 84.5 and I don’t believe it has been touched in quite some time.
Check your config and ensure the IP and port are still correct.
