NUT component resources validation error
Hi
I am trying to setup the NUT UPS component.
On the machine where the UPS is connect I have the following data:
[root@server ~]# upsc openups@localhost
battery.capacity: 100
battery.charge: 100
battery.charge.low: 5
battery.charge.warning: 20
battery.current: 0.010
battery.mfr.date:
battery.runtime: 3932100
battery.temperature: 38.10
battery.type:
battery.voltage: 13.48
device.mfr: Mini-Box.Com
device.model: OPEN-UPS
device.serial: PBSO4-LiFePO
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.parameter.synchronous: no
driver.version: 2.7.4
driver.version.data: openUPS HID 0.4
driver.version.internal: 0.41
input.current: 0.019
input.voltage: 15.21
output.current: 1.402
output.voltage: 12.57
ups.mfr: Mini-Box.Com
ups.model: OPEN-UPS
ups.productid: d004
ups.serial: PBSO4-LiFePO
ups.status: OL CHRG
ups.vendorid: 04d8
The problem is that not all the items above can be added in the HA configuration.
I can add input.voltage, battery.voltage, battery.temperature and some other values.
But when I try to add for example output.current and output.voltage the following error is thrown:
2018-02-07 09:37:17 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.nut]: value is not allowed @ data['resources'][4]. Got 'output.voltage'.
output.voltage is valid data from the nut server so it should be allowed by HA configuration.
Yes, it will be great to include output.voltage and input.frequency vars support.
output.voltage isn’t in the component. Im guessing it would just need to be added.
https://github.com/home-assistant/home-assistant/blob/master/homeassistant/components/sensor/nut.py
