NUT integration allow sending commands
Something like this but with easy UI setup:
root@minopia:~# upscmd -l tecnoware
Instant commands supported on UPS [tecnoware]:
beeper.toggle - Toggle the UPS beeper
load.off - Turn off the load immediately
load.on - Turn on the load immediately
shutdown.return - Turn off the load and return when power is back
shutdown.stayoff - Turn off the load and remain off
shutdown.stop - Stop a shutdown in progress
test.battery.start - Start a battery test
test.battery.start.deep - Start a deep battery test
test.battery.start.quick - Start a quick battery test
test.battery.stop - Stop the battery test
root@minopia:~# upscmd tecnoware test.battery.start.quick
Username (root): admin
Password:
OK
This is supported already, see Network UPS Tools (NUT) - Home Assistant
Unfortunately the NUT integration only supports “device actions” for sending commands and not normal services, which limits the usefullness of the command send support. Mostly useless for those of us using lots of YAML and templates.
