NUT Integration - Showing only 4 entities
I am trying to integrate my CyberPower PR1000RTXL2U UPS into Home Assistant. At first I installed a Proxmox VM with Ubuntu Server to run my NUT server. HA was able to see it but was pulling in only 4 entities. I then tried to install the NUT server on the same VM running Home Assistant using the add on and integrations for it, but am only seeing 4 entities with this method too.
The UPS has the RMCARD205 network interface so I am doing this over SNMP, not USB, even though the UPS is rack mounted in the same rack as my Proxmox server. I would prefer not to use the USB cable if possible…
Screenshot 2021-10-25 140709
When I am asked to select the Resources, I am only given the 4 options shown below. Even going back to the integration later, there only are the same 4 resources.
This UPS has a ton of configuration options and information. Also, I ran the upsc command and the list was relatively long. I can’t see anything on the UPS itself where I can configure what is shared, or not, via SNMP.
I am at a loss… can anyone help?
Items discussed above:
EDIT: I found this github issue regarding support of the RMCARD205 but it is unclear to me whether support made it to NUT yet. I am able to see minimal info, but I don’t know whether that means it is fully supported or not.
