NUT no longer working (Permissions)
I had my UPS working great on HA with NUT but it stoped working and dont know which update broke it.
when i try to start it I get this:
[23:43:49] INFO: Starting the UPS drivers...
Network UPS Tools - Megatec/Q1 protocol USB driver 0.14 (2.8.0)
libusb1: Could not open any HID devices: insufficient permissions on everything
No supported devices found. Please check your device availability with 'lsusb'
and make sure you have an up-to-date version of NUT. If this does not help,
try running the driver with at least 'subdriver', 'vendorid' and 'productid'
options specified. Please refer to the man page for details about these options
(man 8 blazer_usb).
Driver failed to start (exit status=1)
Network UPS Tools - UPS driver controller 2.8.0
cont-init: info: /etc/cont-init.d/nut.sh exited 1
My NUT is still working without issue.
Same issue here, specifically after updating to HA Core to 2024.1.6, did you manage to resolve?
Check the runtime directory for nut. Is it owned by user/group nut? Look for /run/nut
ls -l /run
If the directory is not owned by nut:nut, execute:
sudo chown -R nut:nut /run/nut
In case there are leftover pid-files inside nut’s rundir (and nut is not running) remove those:
sudo rm -f /run/nut/*
Now start nut again. Does it work now?
Happy hunting.
Same problem, doesn´t work for me.
The result of ls -l /run was:
The Home Assistant is running on a Raspberry PI 4
@Tamsy thanks for tips however I got that I don’t have a nut user on the system.
So I did some extra reasearch on the web and I found someone with the same problem in github.
And here’s the solution… be ready guys: You only have to complety shutdown the host. I mean turn off the computor that’s running HA. Turn it on again and it’s working. :sweat_smile: :joy:
Go to settings, system, power button on the top right, advance option, shutdown server.
That’s it
Mine remains the same, it doesn’t work at all.
I finally managed to get it to work, but not on the home assistant OS, I followed the steps in the video below and installed the supervised home assistant inside the Raspberry OS. https://www.youtube.com/watch?v=GfYmrrGgzEM
…which most probably greets you with an “Unheathy” and “Unsupported” HA installation.
Settings → System → Repairs → 3 dots upper right → Information about System → Home Assistant Supervisor
same problem here. Shutdown didn’t help…
I’m trying to set-up NUT with HA running in a VM on Synology NAS with a Fortron (FPS) UPS connected. The UPS is visible to the NAS.
Whatever config I try, NUT can’t detect the UPS. I already tried every suggestion mentioned above:
  • changed default driver from usbhid_ups to blazer_usb and nutdrv_qx
  • tried with and without vendorid and productid
  • did a complete restart of HA
I noticed a difference in the reported errors depending on what driver I use. Using usbhid_ups results in:
USB communication driver (libusb 1.0) 0.43
No matching HID UPS found
Using nutdrv_qx results: in:
Can't claim USB device [0665:5161]@0/0: Other error
Network UPS Tools - Generic Q* USB/Serial driver 0.32 (2.8.0)
Does anybody have experience with a similar set-up and could eventually help me out here?
In my case, this error was being thrown because the cable I have is a bit spotty. The RJ45 end needs to be wiggled a bit to get proper contact.
Check your cables!
I’m also getting the same error:
“libusb1: Could not open any HID devices: insufficient permissions on everything”.
This happened right after migrating my setup so I assume it must have something to do with the new platform.
Previously, I had HA OS running as a VM on an x86 laptop. NUT had been working perfectly for the past year or so since I installed it.
I recently bought a “HOME ASSISTANT GREEN” and migrated my setup to this new platform. At that point NUT stopped working. I tried connecting the UPS to APC’s utility on my windows laptop and all seems to be working fine (so I can confirm it’s not a UPS/cable related issue).
Just to give an update on this issue.
I switched to the other USB port and did a power cycle of the GREEN. Once I rebooted, that allowed the driver to succeed in accessing the UPS as a USB device. My issue is solved for now. It apparently had nothing to do with permissions.
That being said, I suspect there may be some issue with the hot pluggability of the USB interface on the GREEN platform. On my previous setup (a windows laptop using a HASSIO vm) I had no issue plugging and unplugging the UPS to the USB port and having NUT recognize it (as expected from a USB device).
I faced exactly the same issue: an APC UPS plugged into a Home Assistant Green USB port throwing “libusb1: Could not open any HID devices: insufficient permissions on everything”. A hard reboot fixed it.
Same problem here:
Home Assistant OS 13.1
Supervisor 2024.09.1
I use the following configuration for APC smart UPS 1500i usb connected:
  • name: apcsmart
    driver: usbhid-ups
    port: auto
    config:
    • vendorid = 051d*
    • productid = 0002*
    • serial = AS0614322014
Last year this configuration was working. I don’t know exactly when it stopped to work
I am still unable to make it work with HAOS despite the fact that the HAOS does see the UPS connected on USB. Even HA does report it on Settings > System > Hardware. Still, NUT reports the permission error and there is no nut user so theere is no /run/nut anywhere - tried at HASS level (port 22222), tried as HA ssh console, root on both.
It makes sense not to see it because NUT must be running from inside one of the containers, must is not clear to me which one and apparently nobody posted hints on related to this.
I am seeing a similar issue. Raspberry Pi5 and nothing has changed in the NUT config for 12 months - and it suddenly stopped working (I’m pretty certain it worked after migrating from the Pi4B to the Pi 5).
I get:
Network UPS Tools - Generic HID driver 0.47 (2.8.0)
The USB cable to the UPS is fine (I have connected it to my laptop with the UPS software running on it and it talks to the UPS just fine).
I have restarted HA many times (including a shutdown and power-cycle) to no avail.
I had the same error message about the insufficient rights?
It was working for a while and I had to move the ups a little and disconnected the usb cable from the home assistant machine. I did t think much about it since it is usb. Well didn’t work after plugging it in again. Power cycled with and without usb cable connected, used other usb input on the machine. Didn’t work.
Out of desperation I reset the config and deleted username and password in the settings for nut.
After putting username and password in, the ups showed up again and is working.
Perhaps something gets screwed up with the settings when the ups disconnects.
Anyway, easy to do and worth atty I would say.
I had deleted the NUT add-on completely, and haven’t got it going again (even though I wrote-down the settings I had used originally)
