I have 2 Proxmox instances running HAOS VMs. They are on the same HA version (2024.2.4).
I’ve installed the NUT add-on on the test one with the most basic configuration - user/pass, default driver (for Eaton Ellipse Pro). All good. Added the integration, all good.
Then a week later I go to my Prod instance and try to do the same setup, even copy-pasting the configuration. Add-on starts the same, startup logs are 1:1 match. However, the integration fails with this message:
Failure getting NUT ups alias, Socket error.
Tried everything to get it to work - reinstall of both the add-on and the integration, restarting the machine, cycling the UPS power, reassigning the USB port - nothing.
I brought back the UPS to my test instance, connected instantly. Any idea on how to debug this?
P.S.: Before posting, I decided to delete the integration from the Test instance and set it up again, now it throws the same error on Test as well. Tried downgrading to Core 2024.1.6 and OS 11.5, same error.
P.S.2: Installed a fresh VM using latest everything - same error:
So now I’m unable to make it work on any system. Any ideas on how to debug this better?
