NUT server HA add-in unreachable from network clients
I successfully installed the NUT add-in in master mode and the NUT integration is working. I can see that TCP port 3493 is listening for connections. But I cannot connect to it from the NUT client on my Windows machine. Has anyone gotten this working or have any suggestions?
Home Assistant OS is running in a VM on an ESXi 7 host. The Windows client is running on Windows 10.
> users:
>   - username: admin
>     password: xxxxxxxxx
>     instcmds:
>       - all
>     actions: []
> devices:
>   - name: myups
>     driver: usbhid-ups
>     port: auto
>     config: []
> mode: netserver
> shutdown_host: false
> upsmon: master
> list_usb_devices: true
> log_level: debug>
> s6-rc: info: service s6rc-oneshot-runner: starting
> s6-rc: info: service s6rc-oneshot-runner successfully started
> s6-rc: info: service base-addon-banner: starting
>  Add-on: Network UPS Tools
>  Manage battery backup (UPS) devices
>  Add-on version: 0.12.0
>  You are running the latest version of this add-on.
>  System: Home Assistant OS 10.2  (amd64 / qemux86-64)
>  Home Assistant Core: 2023.6.2
>  Home Assistant Supervisor: 2023.06.2
>  Please, share the above information when looking for help
>  or support in, e.g., GitHub, forums or the Discord chat.
> s6-rc: info: service base-addon-banner successfully started
> s6-rc: info: service fix-attrs: starting
> s6-rc: info: service base-addon-timezone: starting
> s6-rc: info: service base-addon-log-level: starting
> s6-rc: info: service fix-attrs successfully started
> [03:57:08] INFO: Configuring timezone (America/New_York)...
> Log level is set to DEBUG
> s6-rc: info: service base-addon-log-level successfully started
> s6-rc: info: service base-addon-timezone successfully started
> s6-rc: info: service legacy-cont-init: starting
> cont-init: info: running /etc/cont-init.d/nut.sh
> [03:57:09] INFO: Setting mode to netserver...
> [03:57:09] INFO: Connected USB devices:
> Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
> Bus 002 Device 005: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
> Bus 002 Device 004: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
> Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
> Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
> Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
> [03:57:09] INFO: Generating /etc/nut/upsd.users...
> [03:57:09] INFO: Configuring user: admin
> [03:57:10] DEBUG: Password SHA1: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
> [03:57:10] DEBUG: Requested API resource: https://api.pwnedpasswords.com/range/26CDA
> [03:57:10] DEBUG: API HTTP Response code: 200
> [03:57:10] INFO: Password is NOT in the Have I Been Pwned database! Nice!
> [03:57:10] INFO: Configuring Device named myups...
> [03:57:10] INFO: Starting the UPS drivers...
>    0.000000	[D1] Starting UPS: myups
> Using subdriver: APC HID 0.98
> Network UPS Tools - Generic HID driver 0.47 (2.8.0)
> USB communication driver (libusb 1.0) 0.43
> Network UPS Tools - UPS driver controller 2.8.0
> cont-init: info: /etc/cont-init.d/nut.sh exited 0
> cont-init: info: running /etc/cont-init.d/nutclient.sh
> cont-init: info: /etc/cont-init.d/nutclient.sh exited 0
> s6-rc: info: service legacy-cont-init successfully started
> s6-rc: info: service legacy-services: starting
> services-up: info: copying legacy longrun upsd (no readiness notification)
> services-up: info: copying legacy longrun upsmon (no readiness notification)
> s6-rc: info: service legacy-services successfully started
> [03:57:11] INFO: Starting the UPS information server...
>    0.000000	fopen /run/nut/upsd.pid: No such file or directory
>    0.000310	Could not find PID file '/run/nut/upsd.pid' to see if previous upsd instance is already running!
>    0.001036	[D1] debug level is '1'
>    0.001277	listening on 0.0.0.0 port 3493
>    0.001769	Connected to UPS [myups]: usbhid-ups-myups
>    0.002625	Running as foreground process, not saving a PID file
> [03:57:11] INFO: Starting the UPS monitor and shutdown controller...
>    0.000000	fopen /run/nut/upsmon.pid: No such file or directory
>    0.000024	Could not find PID file to see if previous upsmon instance is already running!
>    0.000107	Using power down flag file /etc/killpower
>    0.000153	UPS: myups@localhost (primary) (power value 1)
>    0.000164	[D1] debug level is '1'
>    0.000179	[D1] debug level is '1'
>    0.000181	Warning: running as one big root process by request (upsmon -p)
>    0.000218	[D1] Saving PID 469 into /run/nut/upsmon.pid
> Init SSL without certificate database
>    0.081348	[D1] Trying to connect to UPS [myups@localhost]
>    0.551103	User [email protected] logged into UPS [myups]
>    0.082599	[D1] Logged into UPS myups@localhost
I had the same log errors. Go to your integrations and add the NUT tool. Under host add " a0d7b954-nut" then leave the port auto filled and add your credentials and it should work.
Thank you, that was the solution to the problem I had earlier, getting the integration to work. Using that host name in the NUT integration works just fine.
But now I’m trying to get the client on my Windows desktop to connect to the NUT server Home Assistant add-on. No solution so far.
