NUT USB continous disconects
Hi all, I have an issue that I’m not sure how it starts.
I got a Ups Cyberpower 425v 255w Cp425sLG that has the option to connect by USB to my home assistant system. I was very happy as the integrations was very easy, just plug in, reset my machine and it detect it automatically, I was running like this by about 1 month.
After this time, I have changed from 0.114 to 0.115 updates (And I have been installing all the 0.115 updates as they are released). The break of the system do not correlates to any update.
I start getting the following loop on the system console.
As you can see the USB port is detected as a cyberpower device, and then the USB conection is ended and it loops all the day.
I decide to remove the integration, disconect everything and try again, with no success. Even after removing the integration and rebooting, I can’t no longer set it up, as the hardware do not detect the UPS. but the console records remaing the same as the previews photo.
My system is the standar Hassos image for proxmox, mounted in a virtual machine.
When I open my proxmox enviroment and check on harder the USB port is passed out to HA and it says its a UPS.
The interesting part is that my log on HA do not show any error.
How can I debug this issue?
IF I need to add more information, please let me know.
I have a bunch of Cyberpower UPS’s and this is a known bug with the nut USB driver. It seems that the CyberPower controller likes to reset the USB connection on a specific interval. Some people have posted (on other forums) some work arounds, but they didnt work for me. The only thing I could do to get it to stay connected for a long period of time is to create a cron job to restart the nut-driver services every 20 minutes. Overkill? yes. But I have not had any data gaps (and therefore not gaps in shutdown protection) since I did this.
This is my crontab entry on the machine its connected to:
*/20 * * * * systemctl restart nut-driver
Thanks gregg, not sure this will work for me, as the speed of the restart is every few seconds.
Did you have any link to those sites? maybe any of those fixes hopefully will work for me.
The extrangest thing is that it work correctly for me for more than a month and sudenly it stop working.
Thanks again for your comments.
Here’s one page I bookmarked. It has a few tweaks to try. The issue seems worse on some units than others.
If you search for “NUT data stale” youll get a lot of results similar to this.
Thanks I will take a look on that and try to find more information.
I will connect this to a ubuntu PC I have to see if this problem is as showed on your link or if is something related to the interaction with my NUC PC or home assistant.
HAve a nice day.
In UPS.CONF, changing the poll interval from 3 seconds to 15 seconds fixed the problem for my CyberPower:
[cyberpower1]
        driver = usbhid-ups
        port = auto
        desc = "CyberPower BRG850AVRLCD"
        pollinterval = 15
Sorry where do I put that information? I just plugged to my NUC that have my HA installation and pass the port to it.
Thanks for your help.
On the Raspberry PI that I have NUT installed and attached to the CyberPower via USB, ups.conf is located in:
/etc/nut
Ok, when I arrive home will try to look for that file and will let you know if it works.
Hi dproffer, I try to check your commendation on my system and was not able to find the folder, I do not have it on the proxmox machine main system nor on the HA drivers.
Not sure if someone else have a different recommendation.
Regards.
Good hunting! I am not familar with proxmox virtualization system. I run NUT on a rpi right in the raspbian linux. Somewhere NUT has to have a ups.conf file, I would doubt it will run without it. Hope you can find it as it does sound like the core problem you are facing is similar to the one I had.
My ST625 was failing due to constant USB disconnects, crashing the Pi zero it was connected to as well. Changing the poll to 15 seconds has made it very stable. 4 days now!
@dproffer – our units have a current wattage / load. In the PPB website, it’s listed in their javascript API as Output, titled “watts” – however, I couldn’t find anything in the latest MIB file that showed this.
Second, the “current load” MIB item which says “a percent of the load” is constantly at 27%, and doesn’t seem to be changing even when the display is. I was hoping to reverse engineer this percentage to show current watts load, but it’s static.
Have you run into any of these?
Sorry, I do not have any experience with MIB or direct API to any specific UPS vendor’s data. I just consume the data that NUT app extracts from my Cyberpower UPS’s:
user@macmini2012:~/nut_ups$ upsc [email protected]
Init SSL without certificate database
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 20
battery.mfr.date: CPS
battery.runtime: 3720
battery.runtime.low: 300
battery.type: PbAcid
battery.voltage: 24.0
battery.voltage.nominal: 24
device.mfr: CPS
device.model: CST135XLU
device.serial: CDQJQ2000000
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.parameter.synchronous: no
driver.version: 2.7.4
driver.version.data: CyberPower HID 0.4
driver.version.internal: 0.41
input.voltage: 118.0
input.voltage.nominal: 120
output.voltage: 142.0
ups.beeper.status: enabled
ups.delay.shutdown: 20
ups.delay.start: 30
ups.load: 11
ups.mfr: CPS
ups.model: CST135XLU
ups.productid: 0501
ups.realpower.nominal: 810
ups.serial: CDQJQ2006641
ups.status: OL
ups.test.result: No test initiated
ups.timer.shutdown: -60
ups.timer.start: -60
ups.vendorid: 0764
Oh, man thx for that hint - it automagically solved the problem :+1:
Welcome! Lots of good info here on these forums. We all learn from others ‘experience’…
Good hunting!
