I have tried multiple times to get NUT working with my set up - need help.
I have a RPi4 running the latest HA install (not sure what to call it, but it’s the version for numpties like me…docker containers and everything). I have an APC Smart-UPS 1000 plugged into the RPi via USB cable.
I have installed the NUT Add-on and configured it. Here’s my config:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] nut: applying...
[fix-attrs.d] nut: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Network UPS Tools
Manage battery backup (UPS) devices
Add-on version: 0.2.0
You are running the latest version of this add-on.
System: HassOS 4.11 (armv7 / raspberrypi4)
Home Assistant Core: 0.112.3
Home Assistant Supervisor: 228
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nut.sh: executing...
[18:19:09] INFO: Setting mode to netserver...
[18:19:10] INFO: Generating /etc/nut/upsd.users...
[18:19:10] INFO: Configuring user: Username
[18:19:11] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[18:19:12] INFO: Configuring Device named myups...
[18:19:12] INFO: Starting the UPS drivers...
Network UPS Tools - UPS driver controller 3.8.0-3396-gcdc7c4b5b1
Network UPS Tools - APC Smart protocol driver 3.1 (3.8.0-3396-gcdc7c4b5b1)
Fatal error: unusable configuration
APC command table version 3.1
Unable to open auto: No such file or directory
Things to try:
- Check 'port=' in ups.conf
- Check owner/permissions of all parts of path
Driver failed to start (exit status=1)
[cont-init.d] nut.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
I am at a complete loss. Would very much appreciate any help anyone can render.
Thanks,
Phil
Marc,
Thanks for that. I set the port to 3493, but still no joy.
Things to try:
I changed the driver to generic, and put in the vendor ID for APC. Now the log shows this:
[07:33:32] INFO: Setting mode to netserver...
[07:33:32] INFO: Generating /etc/nut/upsd.users...
[07:33:32] INFO: Configuring user: Thibodeaux
[07:33:34] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[07:33:35] INFO: Configuring Device named myups...
[07:33:36] INFO: Starting the UPS drivers...
Network UPS Tools - Generic HID driver 0.41 (3.8.0-3396-gcdc7c4b5b1)
Using subdriver: APC HID 0.96
USB communication driver 0.33
[cont-init.d] nut.sh: exited 0.
[cont-init.d] nutclient.sh: executing...
[cont-init.d] nutclient.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[07:33:36] INFO: Starting the UPS information server...
Network UPS Tools upsd 3.8.0-3396-gcdc7c4b5b1
0.000000 fopen /var/run/nut/upsd.pid: No such file or directory
0.000406 listening on 0.0.0.0 port 3493
0.001621 Connected to UPS [myups]: usbhid-ups-myups
[07:33:37] INFO: Starting the UPS monitor and shutdown controller...
Network UPS Tools upsmon 3.8.0-3396-gcdc7c4b5b1
0.000000 fopen /var/run/upsmon.pid: No such file or directory
0.000832 Using power down flag file /etc/killpower
0.001455 UPS: myups@localhost (master) (power value 1)
0.001625 debug level is '1'
0.001660 Warning: running as one big root process by request (upsmon -p)
0.009584 Trying to connect to UPS [myups@localhost]
0.529189 User [email protected] logged into UPS [myups]
0.010806 Logged into UPS myups@localhost
Which looks good, but I can’t get a sensor to work. I’ve used the example in the documentation, and some others I found. Here’s what I have currently:
I don’t think 127.0.0.1 will work, because that’s the local host of the homeassistant container. Try the ip address for the machine (like 192.168.0.200 or whatever). Remember to restart homeassistant for your changes to take effect.
I got it to work. I have NO idea what I did, but it just started working…
The crazy part is, I commented out the sensor in my config file…but all the entities show up.
Hi, did you ever get a resolve on this one?
I am getting the same Check ‘port=’ in ups.conf error when I user the powercom driver.
I managed to get NUT installed on raspbian and it works with the usbhid-ups driver on raspbian, but I can’t get it working with the Home Assistant addon using exacly the same settings in the config file.
Note that the name ups and user monuser make this compatible with my Synology NAS. They do not need to be those values if you are connecting something else.
Thank you so much for this! Was trying to connect an APC ES-700 to my HA and was not playing. (at all) This config worked perfectly! Both my Readynas can also connect to the remote UPS now. Jackanackanory.
Is there any other setup that you made to make this work with Synology NAS? I put “ups” and “monuser” just like you but my Synology NAS still does not recognise the network UPS, I can’t figure this out
It’s been a long time since I looked at it and my NAS is no longer in the same house as my HA, but that is the only config that I got to work. I have a Synology DS412+ if that makes a difference.
Thanks anyway and sorry for the necrobump. In the meantime, I set an automation that shuts down my NAS after 10 minutes with no power. In this way I do not need to configure the UPS in the NAS for now, I will keep looking into it
I have a APC ES 700 and used @safepay config but can’t get it to play, at all. Did you do anything else? The UPS is connected and the log gives me:
[15:04:37] INFO: Starting the UPS drivers...
Using subdriver: APC HID 0.98
Network UPS Tools - Generic HID driver 0.47 (2.8.0)
USB communication driver (libusb 1.0) 0.43
Network UPS Tools - UPS driver controller 2.8.0
[15:04:37] WARNING: UPS Shutdown will shutdown the host
cont-init: info: /etc/cont-init.d/nut.sh exited 0
cont-init: info: running /etc/cont-init.d/nutclient.sh
cont-init: info: /etc/cont-init.d/nutclient.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun upsd (no readiness notification)
services-up: info: copying legacy longrun upsmon (no readiness notification)
s6-rc: info: service legacy-services successfully started
[15:04:39] INFO: Starting the UPS information server...
0.000000 fopen /run/nut/upsd.pid: No such file or directory
0.000081 Could not find PID file '/run/nut/upsd.pid' to see if previous upsd instance is already running!
0.000878 [D1] debug level is '1'
0.001262 listening on 0.0.0.0 port 3493
0.002095 Connected to UPS [ups]: usbhid-ups-ups
0.004365 Running as foreground process, not saving a PID file
[15:04:39] INFO: Starting the UPS monitor and shutdown controller...
0.000000 fopen /run/nut/upsmon.pid: No such file or directory
0.000074 Could not find PID file to see if previous upsmon instance is already running!
0.000559 Using power down flag file /etc/killpower
0.000857 UPS: ups@localhost (primary) (power value 1)
0.001217 [D1] debug level is '1'
0.001397 [D1] debug level is '1'
0.001421 Warning: running as one big root process by request (upsmon -p)
0.001700 [D1] Saving PID 462 into /run/nut/upsmon.pid
Init SSL without certificate database
0.009517 [D1] Trying to connect to UPS [ups@localhost]
0.491934 User [email protected] logged into UPS [ups]
0.011793 [D1] Logged into UPS ups@localhost
I’m do not understand much of what’s going on and how to debug or continue. Any information would be of value.
