Hi.
Is it possible to connect NUT USB signal cable of an ups directly to USB port in HA Green? Did anyone tried yet? Will it work with the integration?
While I do not have a Home Assistant Green, I do have a Home Assistant Yellow. I have a USB cable connected between my HA Yellow and my CyberPower UPS. I am using the NUT add-on and integration in HA and it works great!
Hopefully it will work just as well on the HA Green. Good luck!
Yes it will work.
You will need the NUT add-on to communicate with your UPS.
You will need the NUT integration for HA to communicate with the add-on.
