NUT with HA
Hi all
Hoping somebody can clarify something for me please?
I have a couple of UPS’s each connected to a Raspberry PI via USB and I’m using NUT to monitor those. All of which works well.
I would like to integrate these into HA and I found the NUT integration to do this … or so I thought. However what I am totally confused about is the integration vs addon discussions I have seen.
My understanding is the NUT install on my Raspberry PI’s are set as Net server and therefore the NUT integration is the add on that talks to the Raspberry.
However I then find there are 3 NUT install options from HA … One in the settings/integrations , another in the add on section and a third on the NUT github page.
So which way round is it? does the add on talk to the NUT server and the integration use the add on … or am I missing something here. Because I have no idea how to configure the add on and when I run the integration it asks for localhost/port / user /password and I’ve tried all combinations including he use of the unexplained a0d7b954-nut and it still says failed to connect.
I’m ok at the NUT install on the raspberry as that appears to be setup and working as per various NUT pages I’ve seen , but open to suggestions just in case its not.
So can somebody please clarify how this hangs together as its costing me a fortune in paracetamol
Many thanks
The addon is what is running on your PI’s, i.e. you don’t need it. You just need the integration.
ok thanks … if I don’t need it then are you saying the UPS need to be directly connected to the HA box ( which is also on a separate Rasp PI)
No, you put in the ip and port of your pi hosting the nut software. You may have to open that port on your pi if it’s not open by default.
ok so keep the nut server on the PI with the UPS attached and install the integration and point it to the PI wit the UPS … Yes ?
Tried that for hours and it would not connect
Then make sure the ports are open on your pi’s running the nut software. Verify that you can access the pi over that port from something other than HA to rule out HA being the problem.
Thank you Petro … a quick telnet proved it couldn’t communicate , so slight change to upsd.conf and it working .
Now the big question … I have 2 UPS devices on separate NUT servers ( on PI’s) can I or how do I add a second integration in HA or can I add a second device to the one integration of NUT?
just add it again the same way you did the first time. You can have multiple instances of the integration.
Yeh just found it under the integration and it works !!
Thanks for your help Petro appreciate it
Funny enough, I nut with HA too. You just need the integration where you’ll enter the IP address of your nut server, and of course the nut server needs to have been configured with a password that you can give to HA when you set up the integration.
