Nvidia Shield as a trigger
How would I integrate my Nvidia Shield into HA so that I can use it to trigger some lights when it is turned on?
Thanks.
I don’t have any experience with the Shield as trigger. I use Kodi (on a shield) as trigger for my lights in combination with node red when we watch a tv serie or a movie.
This is my node red. I’m not much a node red wizard but I’m pleased with how it’s working. There is always room for improvement :slight_smile:
[{"id":"7916c53f.64d5fc","type":"tab","label":"Kodi","disabled":false,"info":""},{"id":"f296f904.84fd68","type":"switch","z":"7916c53f.64d5fc","name":"Playing","property":"payload.notification","propertyType":"msg","rules":[{"t":"eq","v":"Player.OnPlay","vt":"str"},{"t":"eq","v":"Player.OnPause","vt":"str"},{"t":"eq","v":"Player.OnStop","vt":"str"},{"t":"eq","v":"System.OnQuit","vt":"str"},{"t":"eq","v":"Player.OnResume","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":520,"y":560,"wires":[["70492b0c.4fce44"],["f053da54.100668"],["e1ff71c.fc6ce9"],["a4051cb4.ee989"],["ea2ab680.75e558"]]},{"id":"74f12f06.04af4","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 1","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.uit_kodi_play","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":300,"wires":[[]]},{"id":"50268326.0540dc","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 2","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.laag_kodi_play","data":"{\"entity_id\":\"light.laag_kodi_play\",\"hs_color\":[300,70],\"brightness\":20}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":360,"wires":[[]]},{"id":"5fb3eb05.9b2ac4","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 1","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.uit_kodi_play","data":"{\"entity_id\":\"light.uit_kodi_play\",\"hs_color\":[36.568,66.275],\"brightness\":70}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":420,"wires":[[]]},{"id":"aa1ab14b.75a2b","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 2","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.laag_kodi_play","data":"{\"entity_id\":\"light.laag_kodi_play\",\"hs_color\":[36.568,66.275],\"brightness\":70}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":480,"wires":[[]]},{"id":"70492b0c.4fce44","type":"change","z":"7916c53f.64d5fc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":480,"wires":[["74f12f06.04af4","50268326.0540dc"]]},{"id":"f053da54.100668","type":"change","z":"7916c53f.64d5fc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":520,"wires":[["5fb3eb05.9b2ac4","aa1ab14b.75a2b"]]},{"id":"e1ff71c.fc6ce9","type":"change","z":"7916c53f.64d5fc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":560,"wires":[["370f57be.d8dc98","2cc39f67.78db1"]]},{"id":"a4051cb4.ee989","type":"change","z":"7916c53f.64d5fc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":600,"wires":[["54703a40.4cf4c4","149a7424.98bb7c"]]},{"id":"ea2ab680.75e558","type":"change","z":"7916c53f.64d5fc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":640,"wires":[["98c88106.6fbfe","578fcfc7.b1873"]]},{"id":"54703a40.4cf4c4","type":"api-current-state","z":"7916c53f.64d5fc","name":"Check lichten aan","server":"2ab4ecb8.43f564","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.laag_kodi_play","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1270,"y":660,"wires":[["88daa390.d8c15"],[]]},{"id":"149a7424.98bb7c","type":"api-current-state","z":"7916c53f.64d5fc","name":"Check lichten aan","server":"2ab4ecb8.43f564","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.laag_kodi_play","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1270,"y":720,"wires":[["c8acc6aa.101168"],[]]},{"id":"88daa390.d8c15","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 1","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"uit","data":"{\"entity_id\":\"light.uit_kodi_play\",\"hs_color\":[36.568,66.275],\"brightness\":145}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1590,"y":640,"wires":[[]]},{"id":"c8acc6aa.101168","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 2","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"uit","data":"{\"entity_id\":\"light.laag_kodi_play\",\"hs_color\":[36.568,66.275],\"brightness\":145}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1590,"y":700,"wires":[[]]},{"id":"b2cddf59.e15df","type":"kodi-in","z":"7916c53f.64d5fc","name":"TS Kodi","controller":"156b5a67.79b156","x":70,"y":560,"wires":[["7f193325.81fb3c","e1b13645.4fef38"]]},{"id":"220f9c8d.b0d624","type":"inject","z":"7916c53f.64d5fc","name":"Player.OnPlay","topic":"","payload":"{\"entity_id\":\"media_player.kodi\",\"notification\":\"Player.OnPlay\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":260,"wires":[["7f193325.81fb3c"]]},{"id":"98317012.4ec5e","type":"inject","z":"7916c53f.64d5fc","name":"Player.OnPauze","topic":"","payload":"{\"entity_id\":\"media_player.kodi\",\"notification\":\"Player.OnPause\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":300,"wires":[["7f193325.81fb3c"]]},{"id":"400c3ff5.25106","type":"inject","z":"7916c53f.64d5fc","name":"Player.OnStop","topic":"","payload":"{\"entity_id\":\"media_player.kodi\",\"notification\":\"Player.OnStop\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":380,"wires":[["7f193325.81fb3c"]]},{"id":"df6b330f.6767c","type":"inject","z":"7916c53f.64d5fc","name":"System.OnQuit","topic":"","payload":"{\"entity_id\":\"media_player.kodi\",\"notification\":\"System.OnQuit\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":420,"wires":[["7f193325.81fb3c"]]},{"id":"1bd73ce7.295aa3","type":"comment","z":"7916c53f.64d5fc","name":"Testing","info":"","x":90,"y":220,"wires":[]},{"id":"2eb617d4.e63ea8","type":"inject","z":"7916c53f.64d5fc","name":"Player.OnResume","topic":"","payload":"{\"entity_id\":\"media_player.kodi\",\"notification\":\"Player.OnResume\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":340,"wires":[["7f193325.81fb3c"]]},{"id":"ea90f3bf.f8f37","type":"comment","z":"7916c53f.64d5fc","name":"Change message","info":"Change massage to prevent API error","x":820,"y":420,"wires":[]},{"id":"b574b0e2.eef89","type":"comment","z":"7916c53f.64d5fc","name":"On play","info":"","x":1390,"y":300,"wires":[]},{"id":"1e516e84.4bb291","type":"comment","z":"7916c53f.64d5fc","name":"On play","info":"","x":1390,"y":360,"wires":[]},{"id":"7a5cafa3.77ebf","type":"comment","z":"7916c53f.64d5fc","name":"On pause","info":"","x":1400,"y":420,"wires":[]},{"id":"17934ee8.25e861","type":"comment","z":"7916c53f.64d5fc","name":"On pause","info":"","x":1400,"y":480,"wires":[]},{"id":"6c094e04.2129f","type":"comment","z":"7916c53f.64d5fc","name":"On stop","info":"","x":1390,"y":540,"wires":[]},{"id":"6a27bc24.10da64","type":"comment","z":"7916c53f.64d5fc","name":"On stop","info":"","x":1390,"y":600,"wires":[]},{"id":"a8be955d.780a48","type":"comment","z":"7916c53f.64d5fc","name":"On play resume","info":"","x":1420,"y":780,"wires":[]},{"id":"31d739e7.6b0cb6","type":"comment","z":"7916c53f.64d5fc","name":"On play resume","info":"","x":1418,"y":835,"wires":[]},{"id":"a695d280.51cf2","type":"comment","z":"7916c53f.64d5fc","name":"On quit","info":"","x":1730,"y":640,"wires":[]},{"id":"4b0c1db9.526f34","type":"comment","z":"7916c53f.64d5fc","name":"On quit","info":"","x":1730,"y":700,"wires":[]},{"id":"7f193325.81fb3c","type":"time-range-switch","z":"7916c53f.64d5fc","name":"Sunset","lat":"52.52383","lon":"5.44604","startTime":"sunsetStart","endTime":"sunrise","startOffset":"-60","endOffset":0,"x":280,"y":560,"wires":[["f296f904.84fd68","7dd08a61.a83934"],["cac84cba.26608"]]},{"id":"cac84cba.26608","type":"api-current-state","z":"7916c53f.64d5fc","name":"","server":"2ab4ecb8.43f564","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.uit_kodi_play","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":430,"y":700,"wires":[["f296f904.84fd68"],[]]},{"id":"370f57be.d8dc98","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 1","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.uit_kodi_play","data":"{\"entity_id\":\"light.uit_kodi_play\",\"hs_color\":[36.568,66.275],\"brightness\":145}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":540,"wires":[[]]},{"id":"2cc39f67.78db1","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 2","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.laag_kodi_play","data":"{\"entity_id\":\"light.laag_kodi_play\",\"hs_color\":[36.568,66.275],\"brightness\":145}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":600,"wires":[[]]},{"id":"98c88106.6fbfe","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 1","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.uit_kodi_play","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":780,"wires":[[]]},{"id":"578fcfc7.b1873","type":"api-call-service","z":"7916c53f.64d5fc","name":"Kodi groep 2","server":"2ab4ecb8.43f564","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"laag","data":"{\"entity_id\":\"light.laag_kodi_play\",\"hs_color\":[300,70],\"brightness\":20}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":840,"wires":[[]]},{"id":"bdb442e6.2922e","type":"comment","z":"7916c53f.64d5fc","name":"Check lichten aan","info":"On te voorkomen dat de lichten aangaan als kodi afsluit als wij al naar bed zijn check op groep laag (deze is altijd aan als kodi speelt). Als deze aan is dan lichten op gewenste stand als deze niet aan is niets doen.","x":1610,"y":580,"wires":[]},{"id":"7dd08a61.a83934","type":"debug","z":"7916c53f.64d5fc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":460,"y":400,"wires":[]},{"id":"e1b13645.4fef38","type":"debug","z":"7916c53f.64d5fc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":180,"y":660,"wires":[]},{"id":"2ab4ecb8.43f564","type":"server","z":"","name":"Home Assistant FaWo","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true},{"id":"156b5a67.79b156","type":"kodi-controller","z":"","name":"Kodi Shield","host":"192.168.1.7","port":"9090"}]
The easiest way is send restful web request to HA on startup (it’s specially formatted URL / web address).
You’ll need to look around for an app that can do that, but I know they exist for Androids.
